Python Plugin: MAC address presence Topic is solved
Xorfor
Post by Xorfor »
Great these Python plugins!!! Will the Domoticz team move all currently supported devices to python plugins?
I created a plugin to detect whether a mobile phone is in the Domoticz network, identified by MAC address. So, no fixed ip addresses are required. Still some work to do.
Please look at: https://github.com/Xorfor/Domoticz/tree ... acpresence
Logread
Re: Python Plugin: MAC address presence
Post by Logread »
I wrote a similar plugin - with wake-on-lan and remote shutdown options - some time ago but did not yet find time to polish it for a public release, however I noted that a simple « arp-scan » did not reliably detect some mobile devices.
I had to force a repeat option for the scan and also move the scanning process to a shell script called by a cron, in order to avoid locking the python thread during a scan.
What is your experience with reliability of detection for mobile devices ?
Xorfor
Post by Xorfor »
@Logread: You are right, the reliability of detection of devices is not very good. That is one of the reasons that I added a timeout of 10 minutes (by default). An other reason for the timeout is that you will not switch off the heating immediately because you leave your home for a minute.
Arp-scan and also arp on windows need some retries to find the devices.
I use a lua script (like this python version) for months and that is working very good.
Rodio
Post by Rodio »
Hi Xorfor,
I'm really interested in this solution, so I installed your plugin and get NO errors ;)
But the device status is not updated either :(
Running v3.8153 on a RPI
Triple checked the MAC adress, phone is pingable.
Logfile during startup (MACadress is deleted by me, same as the attachment) :
2017-12-07 20:16:25.551 (MacDetect) Debug log level set to: 'true'.
2017-12-07 20:16:25.551 (MacDetect) Number of mac items: 1
2017-12-07 20:16:25.551 (MacDetect) 'Mode1':'iPhone,xx:xx:xx:xx:xx:xx'
2017-12-07 20:16:25.551 (MacDetect) 'HardwareID':'9'
2017-12-07 20:16:25.551 (MacDetect) 'Port':'0'
2017-12-07 20:16:25.551 (MacDetect) 'Mode2':'Single'
2017-12-07 20:16:25.551 (MacDetect) 'Author':'Xorfor'
2017-12-07 20:16:25.551 (MacDetect) 'Mode3':'1'
2017-12-07 20:16:25.551 (MacDetect) 'Name':'MacDetect'
2017-12-07 20:16:25.551 (MacDetect) 'HomeFolder':'/home/pi/domoticz/plugins/MacDetect/'
2017-12-07 20:16:25.551 (MacDetect) 'Mode6':'Debug'
2017-12-07 20:16:25.551 (MacDetect) 'Version':'1.0.0'
2017-12-07 20:16:25.551 (MacDetect) 'Mode4':'10'
2017-12-07 20:16:25.551 (MacDetect) 'Key':'macpresence'
2017-12-07 20:16:25.551 (MacDetect) Device count: 1
2017-12-07 20:16:25.551 (MacDetect) Device: 1 - ID: 70, Name: 'iPhone', nValue: 0, sValue: 'Off'
2017-12-07 20:16:25.551 (MacDetect) Device ID: '70'
2017-12-07 20:16:25.551 (MacDetect) Device Name: 'iPhone'
2017-12-07 20:16:25.551 (MacDetect) Device nValue: 0
2017-12-07 20:16:25.551 (MacDetect) Device sValue: 'Off'
2017-12-07 20:16:25.551 (MacDetect) Device LastLevel: 0
2017-12-07 20:16:25.551 (MacDetect) Heartbeat interval set to: 60.
Logfile during 'normal use' :
2017-12-07 20:38:34.734 (MacDetect) Calling message handler 'onHeartbeat'.
2017-12-07 20:38:34.734 (MacDetect) onHeartbeat called
2017-12-07 20:38:34.780 (MacDetect) num: 1
2017-12-07 20:38:34.780 (MacDetect) Name: iPhone
2017-12-07 20:38:34.780 (MacDetect) No addresses found
Device screenshot
Device screenshot
Schermafbeelding 2017-12-07 om 21.09.54.png (20.31 KiB) Viewed 8622 times
Hardware screenshot
Hardware screenshot
Xorfor
Post by Xorfor »
Did you install arp-scan???
I forgot to mention it in the readme. I just did an update.
The installation can be done (on Raspberry Pi) by:
sudo arpt-get arp-scan -y
Hope this helps. Be aware that arp-scan is not a bullet proof solution to scan mac addresses. But with a timeout of 10 minutes, I didn't have any problem with 3 mac addresses.
Rodio
Post by Rodio »
installed arp-scan now ;)
Rebooted several time, because of error MacDetect ended abruptly (i think)
after 3rd reboot the errors disappeared .
Now I get this messages, but both phones are active at this moment (AccesPoints (apple airport) see them both.
2017-12-09 18:51:49.985 (MacDetect) Calling message handler 'onHeartbeat'.
2017-12-09 18:51:49.985 (MacDetect) onHeartbeat called
2017-12-09 18:51:53.231 (MacDetect) num: 1
2017-12-09 18:51:53.231 (MacDetect) Name: iPhone
2017-12-09 18:51:53.231 (MacDetect) address: 98:CA:......... not found
2017-12-09 18:51:53.231 (MacDetect) num: 2
2017-12-09 18:51:53.231 (MacDetect) Name: S6
2017-12-09 18:51:53.231 (MacDetect) address: E8:50:.......... not found
edit: typo
Xorfor
Post by Xorfor »
@Rodio
Did you try on console: sudo arp-scan -lq? This is actual what the plugin is executing. Sometimes it will take a while before a device gets listed.
EdwinK
Post by EdwinK »
Could this (and your other script) also be used stand-alone. I (and others) seem to have problems running plugins from the RPI.
Xorfor
Post by Xorfor »
@EdwinK: This is the 'old' LUA code I used:
-- List of smartphones with the mac address
local smartphones={}
smartphones['Name1']='xx:xx:xx:xx:xx:xx'
smartphones['Name2']='xx:xx:xx:xx:xx:xx'
smartphones['Name3']='xx:xx:xx:xx:xx:xx'
function timedifference(s)
  year = string.sub(s, 1, 4)
  month = string.sub(s, 6, 7)
  day = string.sub(s, 9, 10)
  hour = string.sub(s, 12, 13)
  t1 = os.time()
  return difference
-- save list of connected devices
os.execute("sudo arp-scan -l -q > /tmp/scan-arp.txt")
for key, mac in pairs(smartphones) do
  -- search for the mac address in the temporary file
  local mac_success=os.execute("sudo grep -e " .. mac .. " /tmp/scan-arp.txt")
  if mac_success then
    -- device available, or wait 5 minutes
    if (
        otherdevices[key] ~= 'On'
        or timedifference(otherdevices_lastupdate[key]) > 300
    then
      print("MAC address: " .. key .. " (" .. mac .. ") in LAN")
      commandArray[key] = 'On'
    -- device not detected after 10 minutes, then switch off
    if (
        (otherdevices[key] ~= 'Off' and timedifference(otherdevices_lastupdate[key]) > 600)
        or timedifference(otherdevices_lastupdate[key]) > 1800
    then
      print("MAC address: " .. key .. " (" .. mac .. ") not in LAN")
      commandArray[key] = 'Off'
Create a dummy device (this is not working with 3.8775, so wait for a fix for that) with a switch for each mac address (mobile phone). Create in Events a new LUA/Time event with above code. Replace Name1 ... Name3 (or more) with the names of the just created switches and fill in the corresponding mac addresses.
EdwinK
Post by EdwinK »
Thanks. Looking into this one
Rodio
Post by Rodio »
Hi Xorfor,
I got an answer, including the MACs of the 2 phones, but still Domoticz doesn't seem to know.
What I noticed is that the arp-scan returns lower-caps, so I changed one of the devices in lowercaps.
Did not help :-(
Thx
R
Xorfor
Post by Xorfor »
@Rodio: I made some improvements and added extra debugging. Can you please try the latest version.
Rodio
Post by Rodio »
:oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops: :oops:
ehhhhh
:oops:
sooooooooo heeeeeee
stupid me, the lowercase was the solution.
But I didn't notice the extra space I put behind the devicename.
I entered 'S6, xx:xx:xx:xx' instead of S6,xx:xx:xx:xx.
So now both devices work :D
so my solution is 'S6,12:a3:bc:d4:56:ef'
I'm happy and gonna test some more.
@Xorfor, thx for the help.
I really appreciate it
Rodio
Post by Rodio »
The new version logfile:
I disabled the WiFi of the S6, just to test.
2017-12-11 22:54:17.969 (DetectMac) Debug log level set to: 'true'.
2017-12-11 22:54:18.170 (DetectMac) Number of mac items: 2
2017-12-11 22:54:18.170 (DetectMac) num: 1
2017-12-11 22:54:18.170 (DetectMac) self.timeouts[num]: 10
2017-12-11 22:54:18.170 (DetectMac) Creating device 'iPhone7'.
2017-12-11 22:54:18.172 (DetectMac) num: 2
2017-12-11 22:54:18.172 (DetectMac) self.timeouts[num]: 10
2017-12-11 22:54:18.172 (DetectMac) Creating device 'S6'.
2017-12-11 22:54:18.173 (DetectMac) 'Author':'Xorfor'
2017-12-11 22:54:18.173 (DetectMac) 'Port':'0'
2017-12-11 22:54:18.173 (DetectMac) 'Version':'1.2.0'
2017-12-11 22:54:18.173 (DetectMac) 'Mode6':'Debug'
2017-12-11 22:54:18.173 (DetectMac) 'Mode4':'10'
2017-12-11 22:54:18.173 (DetectMac) 'Mode1':'iPhone7,xx:xx:xx:xx:xx:xx|S6,xx:xx:xx:xx:xx:xx'
2017-12-11 22:54:18.173 (DetectMac) 'HomeFolder':'/home/pi/domoticz/plugins/MacDetect/'
2017-12-11 22:54:18.173 (DetectMac) 'Name':'DetectMac'
2017-12-11 22:54:18.173 (DetectMac) 'Mode2':'Multiple'
2017-12-11 22:54:18.173 (DetectMac) 'HardwareID':'10'
2017-12-11 22:54:18.173 (DetectMac) 'Key':'macpresence'
2017-12-11 22:54:18.173 (DetectMac) 'Mode3':'1'
2017-12-11 22:54:18.173 (DetectMac) Device count: 2
2017-12-11 22:54:18.173 (DetectMac) Device: 1 - ID: 116, Name: 'DetectMac - iPhone7', nValue: 0, sValue: ''
2017-12-11 22:54:18.173 (DetectMac) Device ID: '116'
2017-12-11 22:54:18.173 (DetectMac) Device Name: 'DetectMac - iPhone7'
2017-12-11 22:54:18.173 (DetectMac) Device nValue: 0
2017-12-11 22:54:18.173 (DetectMac) Device sValue: ''
2017-12-11 22:54:18.173 (DetectMac) Device LastLevel: 0
2017-12-11 22:54:18.173 (DetectMac) Device: 2 - ID: 117, Name: 'DetectMac - S6', nValue: 0, sValue: ''
2017-12-11 22:54:18.173 (DetectMac) Device ID: '117'
2017-12-11 22:54:18.173 (DetectMac) Device Name: 'DetectMac - S6'
2017-12-11 22:54:18.174 (DetectMac) Device nValue: 0
2017-12-11 22:54:18.174 (DetectMac) Device sValue: ''
2017-12-11 22:54:18.174 (DetectMac) Device LastLevel: 0
2017-12-11 22:54:18.224 (DetectMac) Heartbeat interval set to: 60.
2017-12-11 22:54:20.127 (DetectMac) Calling message handler 'onHeartbeat'.
2017-12-11 22:54:20.127 (DetectMac) onHeartbeat called
2017-12-11 22:54:23.528 (DetectMac) num: 1
2017-12-11 22:54:23.528 (DetectMac) Name: iPhone7
2017-12-11 22:54:23.528 (DetectMac) pos: 454
2017-12-11 22:54:23.528 (DetectMac) address: xx:xx:xx:xx:xx:xx found
2017-12-11 22:54:23.528 (DetectMac) num: 2
2017-12-11 22:54:23.528 (DetectMac) Name: S6
2017-12-11 22:54:23.528 (DetectMac) pos: -1
2017-12-11 22:54:25.532 (DetectMac) Calling message handler 'onStop'.
Rodio
Post by Rodio »
And turned the Wifi ON
2017-12-11 22:58:27.538 (DetectMac) onHeartbeat called
2017-12-11 22:58:30.857 (DetectMac) num: 1
2017-12-11 22:58:30.857 (DetectMac) Name: iPhone7
2017-12-11 22:58:30.858 (DetectMac) pos: 485
2017-12-11 22:58:30.858 (DetectMac) address: xx:xx:xx:xx:xx:xx found
2017-12-11 22:58:30.858 (DetectMac) num: 2
2017-12-11 22:58:30.858 (DetectMac) Name: S6
2017-12-11 22:58:30.858 (DetectMac) pos: 423
2017-12-11 22:58:30.858 (DetectMac - S6) Updating device from 0:'' to have values 1:'On'.
2017-12-11 22:58:30.874 (DetectMac) Update 1:'On' (DetectMac - S6)
Xorfor
Post by Xorfor »
Thnx for the test!!! I will put this on the todo list, to remove white spaces.
Rodio
Post by Rodio »
Top
Cheers
R
refthoom
Post by refthoom »
Hi Xorfor, do you think it's possible to have a version without arp-scan? That would make it usable in more situations.
I'm no programmer of any sorts but I tried this in a shell:
#flush cache to get rid of old stuff
sudo ip -s -s neigh flush all
#look for the mac on the network
arp -a | grep -v incomplete | grep -i "xx:xx:xx:xx:xx:xx" > phone
This gives me a file named 'phone' with mac and IP address on one line. So no need for arp-scan :)
Is this something you could use in your script as an alternative?
Bolten88
Post by Bolten88 »
Is this plugin still working?
