Xiaomi Gateway - Setting light color
Posted: Sunday 03 December 2017 13:26
by misfit
I can dim the light with 'level (%)' but how to set RGB color? (Tried to put hex value in 'number' block but seems thats not the right way
Re: Xiaomi Gateway - Setting light color
Posted: Sunday 03 December 2017 14:54
by DAVIZINHO
i make it in dzvents scripts with this code:
local sceneCmd = 'curl -s -i -H "Accept: application/json" "http://192.168.1.4:8084/json.htm?type=command¶m=setcolbrightnessvalue&idx=20&hue=236&brightness=1&iswhite=false"'
os.execute(sceneCmd)
change the ip and port to conect
change the idx (20 in my case)
change de colour (236 in my case)
and change the brightness (1 in my case)
Posted: Monday 04 December 2017 19:07
by misfit
I see this skeleton when creating a new dzvents script:
devices = {
'myDevice'
domoticz.log('Device ' .. device.name .. ' was changed', domoticz.LOG_INFO)
How to utilize your code, if lets say i want to set the color when a user variable changing? (I set the variable with a timed blocky event.)
Posted: Wednesday 06 December 2017 6:58
by Schorschi
i also try to set the colour of the Xiaomi Gateway with a LUA Script.
But i can only set the brightness with:
commandArray['Xiaomi RGB Gateway']='Set Level:100'
I also tried to set RGB values with Set Level but it does not work.
I don't know which command is needed to set this configuration.
Can some one explain me how to find out this information? Maybe also basicaly how to do it on other devices?
Logfile only shows Set Level if i change the colour in the web interface.
thx.
Posted: Wednesday 06 December 2017 14:00
by Schorschi
i am again.
I also tried this in my lua script:
local sceneCmd = 'curl -s -i -H "Accept: application/json" "http://192.168.178.55:9898/json.htm?type=command¶m=setcolbrightnessvalue&idx=1&hue=236&brightness=100&iswhite=false"'
exec_success = os.execute(sceneCmd)
But the LED light don't switch on and the variable exec_success is nul.
How can i test this os command separately?
If i try it on my console and get no error.
Domosticz is running on an raspi 1. And connected to Xiaomi Gateway V2.
Any ideas?
Thx.
Posted: Wednesday 06 December 2017 14:19
by DAVIZINHO
y use this comand in a dzvents script and works perfect
Posted: Thursday 07 December 2017 10:15
by Schorschi
i get running this command in my lua device script.
But sometimes i get an error => scirpt run for more then 10 seconds ....
Is my raspi 1 to slow???
Some one same experiance? Maybe any ideas?
Thx.
Posted: Monday 12 February 2018 13:00
by QSKONE
Can you add some printscreens = examples how they work?
Posted: Monday 12 February 2018 15:30
by Schorschi
here an example of my lua script.
Addapt your ip and port of your domoticz device
Red = 0xFF0000 --(255,0,0)
GatewayColour = Red
local sceneCmd = 'curl -s -i -H "Accept: application/json" "http://192.168.10.1:8080/json.htm?type=command¶m=setcolbrightnessvalue&idx=1&hex=0x'..string.format("%x", GatewayColour)..'&brightness=100&iswhite=false"'
Posted: Tuesday 13 February 2018 16:56
by QSKONE
Thanks mate, but i am absolute beginner , try to write first script ever .Can you add complete from A to Z script?
Posted: Tuesday 13 February 2018 17:40
by hekm77
QSKONE wrote: Tuesday 13 February 2018 16:56
If interesting, You can try.
You must create two Dummy Switch, type - Dimmer:
miGateway Hue and
miGateway Bri
In the script , enter your username, password, ip and port domoticz.
- Spoiler: show
- 111.png (94.86 KiB) Viewed 7339 times
dzVents 2.4.x
- Spoiler: show
devices = {
'miGateway Hue',
'miGateway Bri'
logging = {
level = domoticz.LOG_ERROR
execute = function(dz, item)
local Gateway = dz.devices('Xiaomi Gateway RGB')
local HueDevice = dz.devices('miGateway Hue')
local BriDevice = dz.devices('miGateway Bri')
url = "http://username:password@ip_ddomoticz:port_domoticz/json.htm?type=command&dparam=setcolbrightnessvalue&"
if HueValue == nil then HueValue = 0 end
if BriValue == nil then BriValue = 0 end
function GatewayOn()
SetScene = 'curl -s '..'"'..url..'idx="'..Gateway.idx..'"&hue="'..HueValue..'"&brightness="'..BriValue..'"&iswhite=false" &'
dz.utils.osExecute('('..SetScene..' > /dev/null)&')
HueValue = dz.utils.round(HueDevice.level * 3.59),0
BriValue = BriDevice.level
if (item.name == 'miGateway Hue') then
if (item.state ~= 'Off') then
if (BriDevice.state == 'Off') then
BriValue = BriDevice.lastLevel
GatewayOn()
BriDevice.dimTo(BriDevice.lastLevel).silent()
item.dimTo(item.level).silent()
GatewayOn()
Gateway.switchOff().checkFirst().silent()
BriDevice.switchOff().checkFirst().silent()
if (item.name == 'miGateway Bri') then
if (HueDevice.state == 'Off') then
HueValue = dz.utils.round(HueDevice.lastLevel * 3.59),0
GatewayOn()
HueDevice.dimTo(HueDevice.lastLevel).silent()
GatewayOn()
HueDevice.switchOff().checkFirst().silent()
Posted: Tuesday 13 February 2018 20:20
by QSKONE
hekm77 many thanks. Domoticz Xiaomi Wiki must including your script because it's very helpful.
Posted: Monday 04 June 2018 2:44
by MarnixO
On a Synology i got an error :
2018-06-04 02:37:37.094 Error: dzVents: Error: ...icz/var/scripts/dzVents/generated_scripts/Xiaomi RGB.lua:26: attempt to index field 'utils' (a nil value)
Posted: Wednesday 19 September 2018 22:13
by Schorschi
to set color for the xiaomi gateway is not working in the last domoticz beta and current gateway fw.
I try it with my old script but can't change the color. The gateway switch always to the last manually selected color.
-- Gateway Colour
commandArray['Xiaomi_RGB_Gateway']='Set Level:'..tostring(GatewayBrightness) -- set brightness LED light from Gateway
-- change colour of gateway
local sceneCmd = 'curl -s -i -H "Accept: application/json" "http://192.168.178.62:8083/json.htm?
any idea?
