Rounding function - am I using it correctly
paul402
Post by paul402 »
After the start help here I am making progress on my project - thanks.
This line works perfectly but has a lot of trailing digits which I want to round to 2 digits.
local inside_AH=(((0.000002*(inside_temp*inside_temp*inside_temp*inside_temp))+(0.0002*(inside_temp*inside_temp*inside_temp))+(0.0095*(inside_temp*inside_temp))+(0.337*inside_temp)+4.9034)*inside_rh)/100
So I add "round(number, decimalPlaces)" as the manual describes ...
local inside_AH=round((((0.000002*(inside_temp*inside_temp*inside_temp*inside_temp))+(0.0002*(inside_temp*inside_temp*inside_temp))+(0.0095*(inside_temp*inside_temp))+(0.337*inside_temp)+4.9034)*inside_rh)/100,2)
and have this which gives me an error "lua:21: attempt to call global 'round' (a nil value)"
What obvious mistake have I made please? I can't see it or I don't understand how to use it properly :(
emme
Domoticz version: latest
Re: Rounding function - am I using it correctly
Post by emme »
round is not a built in function.... you have to define it everytime:
function round(num, numDecimalPlaces)
  local mult = 10^(numDecimalPlaces or 0)
  return math.floor(num * mult + 0.5) / mult
"We always done this way"
dannybloe
Post by dannybloe »
It is a built-in function but you have to call it like:
domoticz.round(number, decimalPlaces)
See Domoticz attributes and methods
paul402
Post by paul402 »
OK dannybloe if it is built in then this didn't work
inside_AH=domoticz.round((((0.000002*(inside_temp*inside_temp*inside_temp*inside_temp))+(0.0002*(inside_temp*inside_temp*inside_temp))+(0.0095*(inside_temp*inside_temp))+(0.337*inside_temp)+4.9034)*inside_rh)/100,2)
and neither did this!
local inside_AH=domoticz.round((((0.000002*(inside_temp*inside_temp*inside_temp*inside_temp))+(0.0002*(inside_temp*inside_temp*inside_temp))+(0.0095*(inside_temp*inside_temp))+(0.337*inside_temp)+4.9034)*inside_rh)/100,2)
What do I have to change in my script? I am baffled! Actually more than baffled. I'm going to drink a whisky and relax :)
dannybloe
Post by dannybloe »
I would first do the calculation and then feed it to the round function. You can print the unrounded value to the log. Have you tried to round a simple value like 1.5?
Make sure you use dzVents 2.3.
paul402
Post by paul402 »
The round function is not available yet for the version I am using so I used this math.floor function which works perfectly for my needs.
inside_AH=math.floor(inside_AH*100)/100
Thanks again for the help
dannybloe
Post by dannybloe »
This is the function that's built in dzVents:
	local round = function(x, n)
		n = math.pow(10, n or 0)
		x = x * n
		if x >= 0 then
			x = math.floor(x + 0.5)
			x = math.ceil(x - 0.5)
		return x / n
I doubt your function does anything at all. When I try it in Lua it doesn't do anything at all.
