lastupdate include a AND
poudenes
Domoticz version: 3.8993
Post by poudenes »
Hi All,
Tried this but that doesn't work:
local Version = '17.11.23'
    active = true,
        timer = {'Every 1 minutes'}
    logging = {marker = 'CHECK LIGHT FOR 15MIN ' ..Version},
    if
    domoticz.devices(18).state == 'On' and domoticz.devices(18).lastUpdate.minutesAgo > 1 -- Bathroom sink
    then
        domoticz.log('--------------------==<[ Check light: Batchroom sink lights are on ]>==--------------------', domoticz.LOG_FORCE)
        os.execute('/home/pi/domoticz/scripts/Peter/speech.sh Bathroom sink lights are on')
when i remove the "domoticz.devices(18).state == 'On' and" then the script work. But i want do a check on the lastUpdate and when lamp is on. Otherwise it will loop all the time
Can someone help me?
dannybloe
Re: lastupdate include a AND
Post by dannybloe »
What kind of device is it?
poudenes
Post by poudenes »
dannybloe wrote: Friday 24 November 2017 14:48 What kind of device is it?
stupid me. I see that the state also can be 'Set Kelvin Level' so i changed it to:
(domoticz.devices(18).state == 'Set Kelvin Level' or domoticz.devices(18).state == 'On') and
now it work :)
dannybloe
Post by dannybloe »
But what kind of device is it?
poudenes
Post by poudenes »
dannybloe wrote: Friday 24 November 2017 15:26 But what kind of device is it?
Its a milight lamp
dannybloe
Post by dannybloe »
That's interesting. Can you do something for me?
Set the log level in domoticz settigns for dzVents to debugging. It will create a file domoticzData.lua in scripts/dzVents. Can you find the section in there that deals with this light and paste the data in here. Clearly we can improve the adapter for this device so we can extract the kelvin information etc.
(it will only create that file when at least one event has occured).
poudenes
Post by poudenes »
dannybloe wrote: Friday 24 November 2017 16:53 That's interesting. Can you do something for me?
The amount of text is to long to post
dannybloe
Post by dannybloe »
Only for that specific device.
So find the section in that dump and copy only that section. Each device is behind a numbered entry.
poudenes
Post by poudenes »
dannybloe wrote: Sunday 26 November 2017 10:49 Only for that specific device.
Do you mean this section:
        [6] = {
                ["timedOut"] = false;
                ["description"] = "";
                ["batteryLevel"] = 255;
                ["data"] = {
                        ["hardwareName"] = "MiLight Controller 1";
                        ["levelVal"] = 99;
                        ["usedByCamera"] = false;
                        ["protected"] = false;
                        ["hardwareType"] = "Limitless/AppLamp/Mi Light with LAN/WiFi interface";
                        ["maxDimLevel"] = 100;
                        ["_nValue"] = 33;
                        ["unit"] = 1;
                        ["hardwareTypeValue"] = 22;
                        ["_state"] = "Set Kelvin Level";
                        ["hardwareID"] = 2;
                        ["icon"] = "dimmer";
                ["name"] = "Slaapkamer";
                ["changed"] = false;
                ["lastUpdate"] = "2017-11-24 16:59:10";
                ["rawData"] = {
                        [1] = "10";
                ["lastLevel"] = 99;
                ["signalLevel"] = 12;
                ["deviceID"] = "1";
                ["id"] = 7;
                ["switchType"] = "Dimmer";
                ["subType"] = "RGBWW";
                ["deviceType"] = "Lighting Limitless/Applamp";
                ["switchTypeValue"] = 7;
                ["baseType"] = "device";
dannybloe
Post by dannybloe »
Yes! That's the one. Now I'd like to have a few versions. First when the device is off. Then two or so where it is on with different kelvin levels.
As I don't have this device myself I'm curious how the GUI looks like for this device in Domoticz. Can you paste a couple of screenshots? What does Domoticz allow you to do with this device? Can you change the color or just the Kelvin level in the GUI?
poudenes
Post by poudenes »
dannybloe wrote: Sunday 26 November 2017 14:29 Yes! That's the one. Now I'd like to have a few versions. First when the device is off. Then two or so where it is on with different kelvin levels.
Here already the screenshots:
I took the dressoir now (light bulbs are same)
I can set Kelvin from 0,25,50,100 but i have a dummy device that send a kelvin level to my bulb using a link
http://127.0.0.1:8081/json.htm?type=com ... &kelvin=10
&kelvin=xx can be from 0 to 100
would be nice to have a slider for the kelvin as well same as brightness
When i have the other information i will post them
dannybloe
Post by dannybloe »
Ok, coz I'm curious about the datagrams coming from Domoticz.
dannybloe
Post by dannybloe »
Could you send me those data dumps for this device with different states/values/colors please? I need it to get a new version out soon.
poudenes
Post by poudenes »
Here the output with the 4 options for kelvin
I haver add 1 kelvin level in a dummy with to activate it in dzVents System using this link in the dummy switch selector:
Kelvin 100%
[7] = {
                ["lastUpdate"] = "2017-11-28 09:29:16";
                ["id"] = 8;
                ["lastLevel"] = 91;
                ["name"] = "Dressoir";
                ["rawData"] = {
                        [1] = "100";
                ["data"] = {
                        ["hardwareID"] = 2;
                        ["levelVal"] = 91;
                        ["_nValue"] = 33;
                        ["unit"] = 2;
                ["deviceID"] = "1";
Kelvin 75%
[7] = {
                ["lastUpdate"] = "2017-11-28 09:31:41";
                ["id"] = 8;
                ["rawData"] = {
                        [1] = "75";
                ["data"] = {
                        ["hardwareID"] = 2;
                        ["levelVal"] = 91;
                        ["_nValue"] = 33;
                        ["unit"] = 2;
                ["lastLevel"] = 91;
                ["deviceID"] = "1";
Kelvin 50%
[7] = {
                ["lastUpdate"] = "2017-11-28 09:32:42";
                ["deviceID"] = "1";
                ["id"] = 8;
                ["data"] = {
                        ["levelVal"] = 91;
                        ["unit"] = 2;
                        ["hardwareID"] = 2;
                        ["_nValue"] = 33;
                ["rawData"] = {
                        [1] = "50";
                ["lastLevel"] = 91;
Kelvin 25%
[7] = {
                ["data"] = {
                        ["hardwareID"] = 2;
                        ["_nValue"] = 33;
                        ["unit"] = 2;
                        ["levelVal"] = 91;
                ["rawData"] = {
                        [1] = "25";
                ["deviceID"] = "1";
                ["id"] = 8;
                ["lastLevel"] = 91;
                ["lastUpdate"] = "2017-11-28 09:33:09";
Kelvin 0%
 [7] = {
                ["data"] = {
                        ["_nValue"] = 33;
                        ["levelVal"] = 91;
                        ["unit"] = 2;
                        ["hardwareID"] = 2;
                ["lastUpdate"] = "2017-11-28 09:33:52";
                ["lastLevel"] = 91;
                ["rawData"] = {
                        [1] = "0";
                ["id"] = 8;
                ["deviceID"] = "1";
poudenes
Post by poudenes »
Here with 4 different colours
Color RED but real color for this bulb is more purple
[7] = {
                ["deviceID"] = "1";
                ["rawData"] = {
                        [1] = "100";
                ["id"] = 8;
                ["lastLevel"] = 92;
                ["lastUpdate"] = "2017-11-28 09:37:56";
                ["data"] = {
                        ["unit"] = 2;
                        ["_nValue"] = 15;
                        ["levelVal"] = 92;
                        ["hardwareID"] = 2;
                        ["_state"] = "Set Level";
Color YELLOW
 [7] = {
                ["deviceID"] = "1";
                ["id"] = 8;
                ["rawData"] = {
                        [1] = "100";
                ["lastLevel"] = 100;
                ["lastUpdate"] = "2017-11-28 09:39:32";
                ["data"] = {
                        ["unit"] = 2;
                        ["_nValue"] = 15;
                        ["hardwareID"] = 2;
                        ["levelVal"] = 100;
Color GREEN
   [7] = {
                ["lastUpdate"] = "2017-11-28 09:40:17";
                ["data"] = {
                        ["levelVal"] = 100;
                        ["hardwareID"] = 2;
                        ["_nValue"] = 15;
                        ["unit"] = 2;
                ["id"] = 8;
                ["deviceID"] = "1";
                ["rawData"] = {
                        [1] = "100";
Color BLUE
    [7] = {
                ["id"] = 8;
                ["rawData"] = {
                        [1] = "100";
                ["deviceID"] = "1";
                ["data"] = {
                        ["levelVal"] = 100;
                        ["hardwareID"] = 2;
                        ["unit"] = 2;
                        ["_nValue"] = 15;
                ["lastUpdate"] = "2017-11-28 09:41:06";
poudenes
Post by poudenes »
Lamp is off
  [7] = {
                ["rawData"] = {
                        [1] = "100";
                ["lastUpdate"] = "2017-11-28 09:42:34";
                ["deviceID"] = "1";
                ["data"] = {
                        ["levelVal"] = 100;
                        ["hardwareID"] = 2;
                        ["_state"] = "Off";
                        ["_nValue"] = 0;
                        ["unit"] = 2;
                ["id"] = 8;
Lamp just turned on without change other old values
   [7] = {
                ["deviceID"] = "1";
                ["lastUpdate"] = "2017-11-28 09:43:31";
                ["data"] = {
                        ["hardwareID"] = 2;
                        ["_nValue"] = 1;
                        ["_state"] = "On";
                        ["levelVal"] = 100;
                        ["unit"] = 2;
                ["rawData"] = {
                        [1] = "100";
                ["id"] = 8;
Lamp in disco modus. I have add 1 disco modus in a dummy switch to activate it:
http://127.0.0.1:8081/json.htm?type=com ... um1&idx=18
     [7] = {
                ["lastUpdate"] = "2017-11-28 09:43:55";
                ["id"] = 8;
                ["rawData"] = {
                        [1] = "0";
                ["data"] = {
                        ["_nValue"] = 24;
                        ["_state"] = "Disco Mode 1";
                        ["hardwareID"] = 2;
                        ["unit"] = 2;
                        ["levelVal"] = 100;
                ["deviceID"] = "1";
dannybloe
Post by dannybloe »
