Standard dzVents template afterMin
DomoticaRob
Domoticz version: V4.9700
Post by DomoticaRob »
There is an error in the standard dzVents template:
It must be:
Suc6!
dannybloe
Re: Standard dzVents template afterMin
Post by dannybloe »
Ah, good catch. Fixed it in the next version. Thanks.
DomoticaRob
Hello Danny,
I have cachet another one:
I think it must be scenes.
Suc6!
DomoticaRob
Can I make my own template?
Where is it stored?
dannybloe
Post by dannybloe »
Not really. It is sort of hard coded into the editor unfortunately :(
DomoticaRob
No problem.
I made my own already, called it dz_Template.lua, start with this one, make my changes and save it with a new name.
dannybloe
Post by dannybloe »
what's the template look like?
DomoticaRob
Hello Danny,
I just use yours with the two corrections -> 'afterMin' and 'scenes'
As soon as I have some time I will make a more extended version with statements I will use often.
-- Check the wiki at
-- http://www.domoticz.com/wiki/%27dzVents%27:_next_generation_LUA_scripting
	-- 'active' controls if this entire script is considered or not
	-- trigger
	-- can be a combination:
		devices = {
			-- scripts is executed if the device that was updated matches with one of these triggers
			'device name', -- device name
			'abc*', -- triggers for all devices which name begins with abc
			258, -- id
		timer = {
			-- timer triggers.. if one matches with the current time then the script is executed
			'at 13:45',
			'at 18:37',
			'every 3 minutes on mon,tue,fri at 16:00-15:00'
	-- actual event code
	-- in case of a timer event or security event, device == nil
		The domoticz object holds all information about your Domoticz system. E.g.:
		local myDevice = domoticz.devices('myDevice')
		local myVariable = domoticz.variables('myUserVariable')
		local myGroup = domoticz.groups('myGroup')
		local myScene = domoticz.scenes('myScene')
		The device object is the device that was triggered due to the device in the 'on' section above.
		-- example
		if (device.state == 'On') then
			device.switchOff().afterMin(2)
			domoticz.notify('Light info', 'The light ' .. device.name .. ' will be switched off soon')
