Fibaro Wall plug inconsistant values
kryptonneke
Post by kryptonneke »
I've got a fibaro wall plug FGWPE-102 that can monitor electricity usage.
The plug exposes a number of devices in domoticz, one of which shows the current power usage (W)(type/subtype = usage/electricity) and the other that shows power usage & energy consumed (kWh) (type/subtype = energy/kwh).
I'm using the power usage reported to monitor when a washing machine starts and to send a noficication when the washer is finished. I've found a script on this site that I adapted to dzVentss like this.
-- Check the wiki at
-- http://www.domoticz.com/wiki/%27dzVents%27:_next_generation_LUA_scripting
	-- 'active' controls if this entire script is considered or not
	-- trigger
		timer = {
			-- timer triggers.. if one matches with the current time then the script is executed
			'every minute'
	-- actual event code
	-- in case of a timer event or security event, device == nil
	    local title                 = "Wasmachine"
	    local powermeter_device     = 'kWh Meter Wasmachine'	            --Name of Z-Wave plug that contains actual consumption of washingmachine (in Watts)
	    local usage_device          = 'Usage Wasmachine'	                --Name of Z-Wave plug that contains actual consumption of washingmachine (in Watts)
	    local status_uservar        = 'wasmachine_status'
        local counter_uservar       = 'wasmachine_counter'               --Name of the uservariable that will contain the counter that is needed
        local idle_minutes          = 10                                --The amount of minutes the consumption has to stay below the 'consumption_lower' value
        local consumption_upper     = 20                                --If usage is higher than this value (Watts), the washingmachine has started
        local consumption_lower     = 5.0                                --If usage is lower than this value (Watts), the washingmachine is idle for a moment/done washing
        local myPowermeterDevice    = domoticz.devices(powermeter_device)
        local myUsageDevice         = domoticz.devices(usage_device)
        local myStatusVar           = domoticz.variables(status_uservar)
        local myCounterVar          = domoticz.variables(counter_uservar)
        --Actual start of the script
		domoticz.log('Checking ' .. title.. ' status:')
        domoticz.log(title .. ': Powermeter device used    : ' .. myPowermeterDevice.name)
        domoticz.log(title .. ': Last update               : ' .. myPowermeterDevice.lastUpdate.getISO())
        domoticz.log(title .. ': Usage                     : ' .. myPowermeterDevice.usage.. 'W')
        domoticz.log(title .. ': WhActual                  : ' .. myPowermeterDevice.WhActual.. 'W')
        --domoticz.log('-------------------------')
        --myWasherPowermeter.dump()
        domoticz.log(title .. ': Usage device used         : ' .. myUsageDevice.name)
        domoticz.log(title .. ': Last update               : ' .. myUsageDevice.lastUpdate.getISO())
        domoticz.log(title .. ': WhActual                  : ' .. myUsageDevice.WhActual .. 'W')
        --myWasherUsage.dump()
        if (myPowermeterDevice.WhActual ~=  myUsageDevice.WhActual) then
            domoticz.log(title .. ': USAGE FROM USAGE METER & POWER METER ARE NOT THE SAME!!!')
        domoticz.log(title .. ': Status     : ' .. myStatusVar.value)
        domoticz.log(title .. ': Counter    : ' .. myCounterVar.value)
        local washer_usage = myUsageDevice.WhActual
		--Status is set to off and actual power used is below lower limit: Washing machine is off
		if (myStatusVar.value == 0) and (washer_usage <= consumption_lower) then
		   domoticz.log('Current power usage (' ..washer_usage.. 'W) remains below lower boundary (' ..consumption_lower.. 'W), ' .. title .. ' is off')
		--Status is set to off but actual power used is above upper limit: Washing machine has started
		if (myStatusVar.value == 0) and (washer_usage > consumption_upper) then
		    myStatusVar.set(1)
            domoticz.log('Current power usage (' ..washer_usage.. 'W) is above upper boundary (' ..consumption_upper.. 'W), so ' .. title .. ' has started!')
            myCounterVar.set(idle_minutes)
        --Status is set to on but actual power used is above upper limit: Washing machine is still washing
		if (myStatusVar.value == 1) and (washer_usage > consumption_upper) then
            domoticz.log('Current power usage (' ..washer_usage.. 'W) is above upper boundary (' ..consumption_upper.. 'W), so ' .. title .. ' is still washing')
            if (myCounterVar.value ~= idle_minutes) then
                domoticz.log('Resetting ' .. title .. ' Idle Timer')
        --Status is set to on but actual power used is below lower limit: Washing machine is idle
		if (myStatusVar.value == 1) and (washer_usage <= consumption_lower) then
		    if (myCounterVar.value == idle_minutes) then
                domoticz.log('Current power usage (' ..washer_usage.. 'W) is below lower boundary (' ..consumption_lower.. 'W), ' .. title .. ' seems idle')
                domoticz.log('Current power usage (' ..washer_usage.. 'W) is below lower boundary (' ..consumption_lower.. 'W), ' .. title .. ' has been idle for ' ..idle_minutes - myCounterVar.value .. ' minutes' )
            myCounterVar.set(myCounterVar.value-1)
        --Washing machine is done
        if (myStatusVar.value == 1) and (myCounterVar.value <= 0) then
            domoticz.log(title .. ' is done!')
            myStatusVar.set(0)
            domoticz.notify(title, 'The ' .. title .. ' is ready!', domoticz.PRIORITY_NORMAL)
Problem is that the values for power usage reported by the two 'devices' is not always consistent (especially at lower values).
What would be the preferred way of monitoring the state of the machine, use the power usage only device or the device that also reports energy consumption.
Besides that I find it so strange that a single plug can report two different values for the same parameter.
daand
Re: Fibaro Wall plug inconsistant values
Post by daand »
Did you ever found out why the Fibaro Wall Plug is sending inconsistent power measurements? I have the exact same issue and did send a support ticket to Fibaro about it. However, thery have not replied (yet?).
Below is my log over incoming values reported by the plug. When plug is off (no power consumption) everything is OK. But when plug is turned on and power is drawn every second measurement in the combined W/Wh channel is reporting 0 on the power usage. This is not correct and also it does not match the value of the single channel that reports only the power (without accumulated counter value).
2017-12-06 01:03:29.181 LUA: Effekt: 0.0 (W)
2017-12-06 01:03:29.184 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 01:35:50.199 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 02:03:29.180 LUA: Effekt: 0.0 (W)
2017-12-06 02:03:29.184 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 02:35:50.177 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 03:03:29.182 LUA: Effekt: 0.0 (W)
2017-12-06 03:03:29.185 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 03:35:50.174 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 04:03:29.173 LUA: Effekt: 0.0 (W)
2017-12-06 04:03:29.176 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 04:35:50.191 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 05:03:29.170 LUA: Effekt: 0.0 (W)
2017-12-06 05:03:29.174 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 05:35:50.168 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 06:03:29.172 LUA: Effekt: 0.0 (W)
2017-12-06 06:03:29.176 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 06:35:50.164 LUA: Förbrukning: 0.000;1110.000 (W;Wh)
2017-12-06 07:00:01.651 Schedule item started! Name: Brytare, Type: On Time, DevID: 3, Time: 2017-12-06 07:00:01
2017-12-06 07:00:01.652 OpenZWave: Domoticz has send a Switch command! NodeID: 2 (0x02)
2017-12-06 07:00:02.463 LUA: Effekt: 21.6 (W)
2017-12-06 07:00:02.466 LUA: Förbrukning: 21.600;1110.000 (W;Wh)
2017-12-06 07:35:50.183 LUA: Förbrukning: 0.000;1130.000 (W;Wh)
2017-12-06 08:00:02.164 LUA: Effekt: 21.2 (W)
2017-12-06 08:00:02.168 LUA: Förbrukning: 21.200;1130.000 (W;Wh)
2017-12-06 08:35:50.162 LUA: Förbrukning: 0.000;1150.000 (W;Wh)
2017-12-06 09:00:02.160 LUA: Effekt: 21.3 (W)
2017-12-06 09:00:02.165 LUA: Förbrukning: 21.300;1150.000 (W;Wh)
2017-12-06 09:35:50.161 LUA: Förbrukning: 0.000;1170.000 (W;Wh)
2017-12-06 10:00:02.160 LUA: Effekt: 20.9 (W)
2017-12-06 10:00:02.164 LUA: Förbrukning: 20.900;1170.000 (W;Wh)
2017-12-06 10:35:50.180 LUA: Förbrukning: 0.000;1190.000 (W;Wh)
2017-12-06 11:00:02.160 LUA: Effekt: 21.2 (W)
2017-12-06 11:00:02.164 LUA: Förbrukning: 21.200;1190.000 (W;Wh)
2017-12-06 11:35:50.160 LUA: Förbrukning: 0.000;1210.000 (W;Wh)
2017-12-06 12:00:02.172 LUA: Effekt: 21.0 (W)
2017-12-06 12:00:02.175 LUA: Förbrukning: 21.000;1210.000 (W;Wh)
frustreerMeneer
Post by frustreerMeneer »
I'm experiencing the same problem.
Did you find a solution?
