A way to control RGB(W(W))
Posted: Sunday 19 November 2017 13:32
by poudenes
Hi All,
Is it possible to change color to RGB(W(W)) bulbs using dzVents?
Re: A way to control RGB(W(W))
Posted: Tuesday 21 November 2017 13:43
by poudenes
find out that i can use this
os.execute('curl "http://127.0.0.1:8081/json.htm?type=command&param=setcolbrightnessvalue&idx=3&hue=18&brightness=50&iswhite=false"')
hue i can select the color and brightness i can change the level of it
Posted: Wednesday 22 November 2017 8:17
by dannybloe
That's interesting. Are there more commands like these? Maybe useful to add this to the rgbw_device.lua adapter.
Posted: Wednesday 22 November 2017 9:39
by poudenes
dannybloe wrote: Wednesday 22 November 2017 8:17 That's interesting. Are there more commands like these? Maybe useful to add this to the rgbw_device.lua adapter.
You can also use this for kelvin level
http://127.0.0.1:8081/json.htm?type=command&param=setkelvinlevel&idx=8&kelvin=10
Where kelvin=10 can be between 1-100
But for kelvin i created a dummy switch with 10 different kelvin levels :10, 20, 30, 40, 50, 60, 70, 80, 90, 100
The link i use in dzVents was needed to give my MiLight bulbs some color for specific action
Posted: Wednesday 22 November 2017 11:06
by BakSeeDaa
The FIBARO RGBW Controller has 5 nice animation programs built in that can be set using the Domoticz API URL.
Predefined animation programs
6 = Fireplace
7 = Storm
8 = Rainbow
9 = Aurora
10 = LPD
As discussed here the idx parameter i the querystring is not the Domoticz device idx but a hidden "internal Z-wave device idx".
There are some oddities though. If you select an animation program and switch to solid light, it will not switch on the same animation program again (next time). That is, you'd have to turn on another animation program first (turn the animation program off first will also work). Another thing is that if you send several commands without a delay, the device will generate a z-wave timeout. If we use a short delay it will work, almost every time.
Below is an example dzVents script. In current dzVents version (2.3.1) we can not use delays for the openURL command. Thats why I use the function delayedOpenURL() in my script.
I've created a selector switch to trigger the script.
Level	Level name
0	Off
10	Fireplace
20	Storm
30	Rainbow
40	Aurora
50	LPD
60	Solid RED
	active = true,
	logging = {
		level = domoticz.LOG_DEBUG,
		marker = 'RGBW'
		devices = {
			'RGBW Selector'
	data = {
		last_animation_program = {initial=0}
		local RGB_ANIMATION_OFF = 0
		local RGB_ANIMATION_FIREPLACE = 10
		local RGB_ANIMATION_STORM = 20
		local RGB_ANIMATION_RAINBOW = 30
		local RGB_ANIMATION_AURORA = 40
		local RGB_ANIMATION_LPD = 50
		local RGB_DEV = 337
		local RGB_ZW_INT_NODE = 75 -- See: https://www.domoticz.com/forum/viewtopic.php?t=8605
		local function delayedOpenURL(url, delay)
			delay = delay or 0
			if delay == 0 then
				domoticz.openURL(url)
				domoticz.log('Requesting url '..url..' with a delay of '..tostring(delay)..' seconds', domoticz.LOG_DEBUG)
				os.execute('(sleep '..delay..';curl -s "'..url..'" > /dev/null)&')
		local function setRGBWAnimation(rgbAnimation)
			--  Add the number 6-10 to query string, base64- and URL encoded
			local url = domoticz.settings['Domoticz url']..'/json.htm?type=command&param=applyzwavenodeconfig&idx='..RGB_ZW_INT_NODE..'&valuelist=72_'
			local delay = 0
			if rgbAnimation == domoticz.data.last_animation_program then
				if rgbAnimation ~= RGB_ANIMATION_OFF then
					delayedOpenURL(url..'MQ%3D%3D', 0) -- Switch off the animation program first
					delay = 2
				domoticz.data.last_animation_program = rgbAnimation
			if rgbAnimation == RGB_ANIMATION_OFF then
				delayedOpenURL(url..'MQ%3D%3D', delay)
			elseif rgbAnimation == RGB_ANIMATION_FIREPLACE then
				delayedOpenURL(url..'Ng%3D%3D', delay)
			elseif rgbAnimation == RGB_ANIMATION_STORM then
				delayedOpenURL(url..'Nw%3D%3D', delay)
			elseif rgbAnimation == RGB_ANIMATION_RAINBOW then
				delayedOpenURL(url..'OA%3D%3D', delay)
			elseif rgbAnimation == RGB_ANIMATION_AURORA then
				delayedOpenURL(url..'OQ%3D%3D', delay)
			elseif rgbAnimation == RGB_ANIMATION_LPD then
				delayedOpenURL(url..'MTA%3D', delay)
		local function setRGBWChannels(vBrightness, vHex)
			local url = domoticz.settings['Domoticz url']..'/json.htm?type=command&param=setcolbrightnessvalue&idx='..RGB_DEV..'&hex='..vHex..'&brightness='..vBrightness..'&iswhite=false'
		if device.level <= 50 then
			setRGBWAnimation(device.level)
			setRGBWChannels(100, 'ff0000') -- Solid RED
