TS-808 Wireless thermostat
joostvanderlinde
Domoticz version: 2023.2
Post by joostvanderlinde »
To control my underfloor heating valve, I want to use a (wireless) thermostat that I also can control via RFXCom.
Using a simple KaKu switch and a temperature sensor linked via Domottiz could a solution, but the drawback is I cannot simply adjust the temperature in the room by 'pressing a switch'/
I found the TS-808 Wireless Thermostat that seems to be capable of what I want. It looks like a simpe 433MHz switch that is triggered by a temperature sensor/transmitter.
http://www.ebay.nl/itm/TS-808-RF-433MHz ... 2465102186
The specs I have only state that it is 433MHz...
Question is: Will it be controlable (read the transmitter / trigger the receiver) from Domoticz via my RFXCom?
Domoticz on BPI-M2-Pro (compiled on Ubuntu 22.04) and RPI (binary on Raspian 10)
RFXCom, Sonoff Zigbee stick, eBusd Adapter 5, P1, S0, Husdata H60 integration
Zigbee2MQTT AD, MQTT local, AirconWithMe, Ebusd, VolvoRecharge, PSA Car Controller
joostvanderlinde
Re: TS-808 Wireless thermostat
Solved differently.
Bought a cheap but good looking 220V tiuch screen thermostat on eBay
And bought a cheap KaKu clone from Action
Connected thermostat and KaKu clone in parallel to a 240V socket
The socket rhen gets power if either the thermostat or the KaKu are 'on'.
In addition I used a 240V relay to actually switch on/off my 24V Honeywell floor heating valve.
Now I can (manualy or in a blocky event) interfere (based on a temperature sensor I already have) the state of my floor heating...
