How to use an Onkyo Receiver
rizzah
Post by rizzah »
I read this post (https://www.domoticz.com/wiki/Onkyo) about how to manage an Onkyo receiver. However i also noticed that you can add an Onkyo receiver under Hardware. I did this and i got 3 devices back. (master power, master volume and zone 2 power). Im wondering how i can make scenes with the onkyo. For example, change the input to Radio, or Nvidia shield.
Should i still use the php script mentioned in the link to get that done or am i missing something when i added the Onkyo under hardware?
Thanks.
jake
Re: How to use an Onkyo Receiver
Post by jake »
I would like to recommend you to use the python plugin on this forum. Since that one listens to the communication from the receiver directly and reacts immediately, that plugin is superior to the 2 solutions that you chose now.
viewtopic.php?t=16313
leecollings
Post by leecollings »
Just to update here, since the recent update the native Onkyo plugin for Domoticz now includes main and zone 2 input sources as devices.
eddieb
Post by eddieb »
Hi, I am using this builtin with my TX-NR609 (that one is unsupported in the python plugin) and a lot is working ...
But I mis the PLAY/PAUSE/FF/REW/SKIP buttons ...
I use Internet Radio a lot and I need a button to send a PLAY command to my Onkyo to start playing.
Manually sending "http://IP:PORT/json.htm?type=command&param=onkyoeiscpcommand&idx=64&action=NTCPLAY" starts the music
Suggestions ?
RPI4 Beta / Tasmota / ZigBee2MQTT / P1meter / Haier AC MQTTmapper / SolarEdge SE3500H modbus_tcp / Marstek Venus / Opentherm gateway / Plugwise Anna/Smile / ObserverIP weatherstation thru WuDirect
jake
Post by jake »
Simply add your json command to the on command (edit) of a virtual switch that you can create yourself
