Playing Doorbell Sound on Xiaomi Gateway
Posted: Tuesday 14 November 2017 16:51
by nettworker
Hello
i am trying to play the doorbell sound on the Gateway if a Switch is tapped. I tried the following code, but nothing happens:
local sensor = 'Dual Wall Switch'
local schalter = 'Xiaomi Gateway Esszimmer Doorbell'
if (devicechanged[sensor]) then
commandArray['Xiaomi Gateway Esszimmer Volume']='Set Level 25'
commandArray[schalter] = 'Set level 40'
commandArray[schalter] = 'On'
print('-- Schaltvorgang festgestellt--')
print(otherdevices[sensor])
Someone a solution?
Re: Playing Doorbell Sound on Xiaomi Gateway
Posted: Wednesday 15 November 2017 14:25
by nettworker
Tried the following after deleting all items and setup new:
-- loop through all the changed devices
for deviceName,deviceValue in pairs(devicechanged) do
print ("Device based event fired on '"..deviceName.."', value '"..tostring(deviceValue).."'")
-- Auswertung des Mi Schalters ( links ) für die Abendlichter
if (deviceName == 'Mi GW Schalter' and deviceValue == 'Switch 1') then
if ( uservariables['Szenario_Abendlichter'] == 'Off' ) then
print('Abendlichter sind aus, schalte ein...')
commandArray['Scene:Abendlichter'] = "On"
commandArray['Variable:Szenario_Abendlichter'] = 'On'
elseif ( uservariables['Szenario_Abendlichter'] == 'On' ) then
print('Abendlichter sind an, schalte aus...')
commandArray['Scene:Abendlichter'] = "Off"
commandArray['Variable:Szenario_Abendlichter'] = 'Off'
elseif ( deviceName == 'Mi GW Schalter' and deviceValue == 'Switch 2') then
print('-- KLingel sollte angehen --')
--commandArray['Mi GW Klingel'] = 'Set level 40'
commandArray['Mi GW Klingel'] = 'On'
First If Block works with the Scene, but why is the Last Event fired if i set the 'Mi GW Klingel' to 'On'? Don't understand this....
2017-11-15 14:18:19.312 LUA: Device based event fired on 'Mi GW Schalter', value 'Switch 2'
2017-11-15 14:18:19.312 LUA: -- KLingel sollte angehen --
2017-11-15 14:18:19.312 EventSystem: Script event triggered: Switch_Test
2017-11-15 14:18:19.513 LUA: Device based event fired on 'Mi GW Klingel', value 'Off'
commandArray['Mi GW Esszimmer'] = 'On' works and the Light at the Gateway is on......
Posted: Tuesday 21 November 2017 14:15
by nettworker
Noone a Idea?
No Solution from the Developers?
Cant understand that playing sound from the Website ( the automatic generated Icon ) works and if i try it from the Lua Code it will not work and on commandArray['Mi GW Klingel'] = 'Doorbell ring tone' the Event 'Device based event fired on 'Mi GW Klingel', value 'Off'' is fired and nothing works.....
Posted: Tuesday 21 November 2017 14:41
by jimicek
this is a portion of code which works in my Domoticz:
-- sound values:
-- 10 = Doorbell
-- 20 = Knock
-- 30 = Hilarious
-- 40 = Alarm clock
sound = 10
volume = 10
if devicechanged['Zvonek Xiaomi'] == 'Closed' then
commandArray['Xiaomi Gateway Volume']='Set Level '..tostring(volume)
commandArray['Xiaomi Gateway Doorbell']='Set Level '..tostring(sound)
-Jimicek
Posted: Tuesday 21 November 2017 19:58
by nettworker
THX, now it works. Seems it was the missing Gateway Volume.....
Posted: Tuesday 21 November 2017 21:30
by nettworker
Can I set the Color of the Gateway Ligth via LUA?
