Not receiving signals anymore.
Posted: Monday 13 November 2017 23:20
by roblom
For some reason my rfxcom doesn't receive signals anymore in Domoticz. Is does send signals.
When I use the rfxcom with the rfxmanager it works normal (so receive and sending).
I've changed several firmware but it doesn't help.
I've set it to default so undecoded for example is off.
I don't see any error measures regarding the rfxcom in the log.
Somebody an idea?
Re: Not receiving signals anymore.
Posted: Tuesday 14 November 2017 8:12
by SweetPants
An almost dead battery in a PIR maybe? This can screw up your RF reception.
Posted: Tuesday 14 November 2017 8:26
by roblom
I have a pir but it's zwave. I have a lot of different temperature sensors but they all stppped working at the same time.
Posted: Tuesday 14 November 2017 9:07
by b_weijenberg
If possible, check your RFXtrx433E on another location (>500 meters away) on a laptop with RFXmngr.
It could be any sensor or remote with an almost empty battery or a sensor filled with water or a button pressed on a remote.
In most cases it was a X10 MS13 sensor with almost empty battery or an outside sensor filled with water (also check outside sensors from your neighbor).
Posted: Tuesday 14 November 2017 23:33
by roblom
Seems like my owl was causing the problem, it had a dead battery. Strange that a dead battery is causing the device blocking all other signals.
Thanks for the tip.
