Disarm or Ignore Door Switch
Posted: Friday 10 November 2017 14:24
by Underdog85
Need some help trying to figure this out.
I have a bedside wireless switch which turns on/off the bedside lamps and a door sensor which automatically turns the lamps on when opened after sunset.
The issue: When I press the wireless on/off switch the lights go off but then when I open the door they turn back on.
Is there a way I can disarm the door sensor for 30 seconds and then re-arm the door allowing me to exit the room without them tuning back one?
Re: Disarm or Ignore Door Switch
Posted: Friday 10 November 2017 14:52
by emme
sure...
you can use dzVents to work on lastUpdate value....
devices = {
'myDoorDevice'
local lampSwitch = domoticz.devices('myLampSwitch')
local delay = 30 --delay in secs
if device.lastUpdate.secondAgo > delay then
lampSwitch.switchOn().checkFirst()
by this... the door sensor will NOT switch on the light for the next
n secs (based on the value set on delay)
Posted: Friday 10 November 2017 16:11
by Siewert308SW
Or in plain Lua.
function timedifference(s)
year = string.sub(s, 1, 4)
month = string.sub(s, 6, 7)
day = string.sub(s, 9, 10)
hour = string.sub(s, 12, 13)
t1 = os.time()
return difference
if devicechanged["door_switch"] == 'Open'
and otherdevices["bedside_light"] == 'Off'
and timedifference(otherdevices_lastupdate["light_switch"]) >= 30
then
commandArray["bedside_light"]='On'
Posted: Saturday 11 November 2017 15:21
by Underdog85
Thanks both.
I don't have any experience with programming so the above doesn't make any sense to me. Is there a way you can break it down so I know where to insert my devices etc and how I go about this?
