Reset a timing event
dpcreel
Post by dpcreel »
I have a question that has been asked before but I don't think it has been answered - viewtopic.php?f=31&t=19255&p=149148&hil ... in#p149148. It has to do with resetting a timed event. Example if I write
switchOff().afterMin(10) and not(domoticz.devices('motion sensor').bState)
it will activate a switch OFF after 30 min if there is no motion. However if sometime during that 10 min period motion is detected and I want to keep the light ON, the light will still shut OFF after 10 min no matter the status of the motion sensor. No matter if I switchOn().
Is there a way to reset a timed event?
To get around this I have used a function that gets the current time in minutes, add a delay number to it and compare that to the current time in minutes. It can be easily reset at any time unlike afterMin().
Am I missing something? Anything easier?
dannybloe
Re: Reset a timing event
Post by dannybloe »
Yeah, wait for dzVents 2.4.0 (it is in the making now) and it will have a .cancelQueuedCommands() method.
In the meantime, afaik, any new command will also remove the queued commands. So you can try to send a .setState(myDevice.state). That should reset it as well.
BakSeeDaa
Post by BakSeeDaa »
Great news @dannybloe
dzVents keeps getting better and better all the time :)
dpcreel
Post by dpcreel »
Ditto, thanks.
