Problem with z-stick adding devices
Posted: Wednesday 08 November 2017 22:59
I’m a noob, I have domoticz on a pi3, and a z-stick (zwave plus) gen5 plugged into it.
I also have a domitech lamp (zwave plus). A few months ago I configured domoticz using blockly that the lamp turn on At sunset and off at sunrise. Being a noob, I was quite proud of that achievement.
But then I bought a popp radiator thermostat, I was feeling confident, I took the z-stick, held it next to the installed thermostat and tried to include.
Since then my confidence is going down the hill. I noticed that the lamp stopped responding to the schedule, so I left the thermostat and try to get it working again.
No luck unfortunately. I saw the lightbulb in domotics, but turning on or off, the device itself did not follow. I tried resetting the light bulb, resetting the z-stick, in the end I deleted the lightbulb, and tried to add it again with the z-stick.
Problem there is that the lamp reacts as if it is included, (blinks twice) but when I look in hardware- z-stick I see an empty list.
I succeeded one time seeing the lamp, but then I saw two lamps, in stead of one. When I tried to turn it on I got an error sending switch command to device.
Anyway, that time I deleted the device, but now I see empty list.
Hoe can I include and see it in the list?
Anyone knows what may be the issue?
Thanks..
Thanks..
