Page 1 of 2
[Problem] Event with time won't trigger
Posted: Wednesday 08 November 2017 19:57
by cantarevolare
I made this event to turn on the heating in a room when it is under a certain temperature and it is the night.
I think the first works (thanks to the or condition) but the second won't work and I think that when I use time condition, it doesnt' work :
Could you help me, please ?
Thank you in advance.
Re: [Problem] Event with time won't trigger
Posted: Wednesday 08 November 2017 20:09
by jvdz
Both test look wrong to me, but could you start with explaining the what exactly you want to accomplish?
Just describe the logic you want between 7:00-19:00 and between 19:00-7:00 please.
Jos
Posted: Thursday 09 November 2017 11:10
by cantarevolare
Ok, you must be right because this morning, I got a loop
This is what I want to accomplish :
* I want the heating switch to be OFF (but ON IRL) when it is the night (19:00 / 07:00) AND the temperature is under 18 and, of course, the heating switch is not already on OFF ;
* I want the heating switch to be ON (but OFF IRL) when it is the day (07:00 / 19:00) OR when the temperature is above 19 and, of course, when the heating switch is not already on ON.
To sum up, I don't want the room to be cold ONLY the night and I don't want the room to be hot during the day because there is nobody in there.
Thank you in advance for you help.
Posted: Thursday 09 November 2017 18:48
by jvdz
OK so during the daytime it is easy as that is always Off.
During the Night time I would expect the heating to be on when below 18 and Off when above 19 to avoid a flip-flopping effect.
The way you describe it it will only switch on during that time when below 18 and never Off, or did I misinterpret that?
I prefer coding logic in LUA to get much better control but guess The Blockly the scenario could be something like:
if "Radiateur chambre" = "On" and Time > 07:00 and Time < 19:00
Do Set "Radiateur chambre" = "Off"
elseif "Radiateur chambre" = "On" and Time < 07:00 and Chambre temp > 19
elseif "Radiateur chambre" = "On" and Time > 19:00 and Chambre temp > 19
elseif "Radiateur chambre" = "Off" and Time < 07:00 and Chambre temp < 18
Do Set "Radiateur chambre" = "On"
elseif "Radiateur chambre" = "Off" and Time > 19:00 and Chambre temp < 18
Jos
Posted: Thursday 09 November 2017 18:55
by cantarevolare
You don't misinterpret at all : it will only switch on the night when it's under 18. But, if the temperature go above 19 during the night, I expect it to turn off.
I don't mind at all to begin coding in LUA. Could you guide me for the first condition and I'll try to make the rest, please ?
Thank you in advance for your help.
Posted: Thursday 09 November 2017 19:14
by jvdz
cantarevolare wrote: Thursday 09 November 2017 18:55
The turn Off bit wasn't in your explanation though.
I think the posted Blockly should just do what you want. The reason for the 4 Elseif is the fact you need an OR relation for the time test and I am not sure how to put the test in brackets () like you would do in lua.
This should be close but I haven't tested it on syntax errors. Put this into a TIME script and it will run one time per minute on the minute:
time = os.date("*t")
-- Logic between 07:00 - 9:00
if time.hour >= 7 and time.hour <= 21 then
if otherdevices["Radiateur chambre"] == 'On' then
commandArray["Radiateur chambre"]="Off"
else -- logic for the other timeslot
-- get current temp and make that a number
curtemp=tonumber(otherdevices_svalues['Chambre temp'])
if otherdevices["Radiateur chambre"] == 'On' and curtemp > 19 then
elseif otherdevices["Radiateur chambre"] == 'Off' and curtemp < 18 then
-- no action needed
Ask when you need further explanation on the logic.
Jos
Posted: Friday 10 November 2017 9:26
by cantarevolare
Thank you very much.
I just pasted it and I'll see these next days if it match what I wanted to do.
Posted: Thursday 14 December 2017 12:13
by cantarevolare
It won't work
No matter the temperature or the hour of the day, the event triggers and never allows me to switch the heat on :/
Posted: Thursday 14 December 2017 12:32
by emme
well... there is NO instruction to turn ON" Radiateur chambre"
maybe this would help:
commandArray["Radiateur chambre"]="On"
-- no action needed
Posted: Thursday 14 December 2017 13:59
by cantarevolare
Thank you for this quick answer.
If I saw what you changed, that's this part :
But the "commandArray["Radiateur chambre"]="Off"" was good because my switch is reversed : when the switch is "Off", the head switches "On", and vice versa.
Posted: Thursday 14 December 2017 14:00
by emme
uh.. ok... then you have to better check all ON and OFF states in conditions and command... that's the deal
Posted: Thursday 14 December 2017 14:29
by cantarevolare
I don't understand: what are the cases that are not covered by this script, please ? There are already two majors conditions : before or after a certain hour, under or above a certain temperature.
Posted: Thursday 14 December 2017 14:50
by emme
lets' have a deep look to the script:
here your're saying: between 7.00 and 21.59 if Radiateur chambre in ON (= Off) then switch it OFF (=On)
the next portion will ONLY took place between 22.00 and 6.59
if otherdevices["Radiateur chambre"] == 'Off' and curtemp > 19 then
if temp above 19 and Radiateur chambre in ON (= Off) then switch it OFF (=On)
if NOT in this condition (but still between 22.00 and 7.00)
elseif otherdevices["Radiateur chambre"] == 'On' and curtemp < 18 then
if temp under 18 and Radiateur chambre in ON (= Off) then switch it OFF (=On)
are these the condtitions?
Posted: Thursday 14 December 2017 15:10
by cantarevolare
Yes, these are the conditions. (I didn't know that time.hour <= 21 equals 21.59 and not 20.59 but I will correct it)
Posted: Friday 15 December 2017 8:06
by cantarevolare
Is there a way to display the different value of variables in the log (or elsewhere), please ?
It could help me to know, every time it doesn't allow me to turn on (off) the heat, which conditions makes it happens and with which values.
Posted: Friday 15 December 2017 18:37
by cantarevolare
I found myself with print.
I don't understand something, so I repost my script :
if time.hour >= 7 and time.hour <= 18 then
if otherdevices["Radiateur chambre"] == 'Off' then
print("Condition 1")
print(time.hour)
print("Condition 2")
print("Condition 3")
-- no action needed
This code is okay. But when I want to put "time.hour <= 12", it says this error : " 2017-12-15 18:36:36.534 Error: EventSystem: in Chauffage LUA: [string "commandArray = {}..."]:14: attempt to compare number with nil ". It is currently 18:36. If I put a number like 19, 20, 22, etc. no problem. If I put a number before, like 12, 15, 17, etc, it says this error. I don't understand why.
Coudl you help me, please ?
Thank you.
Posted: Tuesday 19 December 2017 13:25
by cantarevolare
up
Posted: Tuesday 19 December 2017 13:37
by jvdz
What is the value of curtemp? ... the result of this line:
print("curtemp:",curtemp)
Guess you need to check the devicename when that is nil!
Jos
Posted: Tuesday 19 December 2017 18:35
by cantarevolare
It says :
2017-12-19 18:30:03.214 dzVents: curtemp:
When I look at the json of the device, I found this :
Temp : 17.1
Posted: Tuesday 19 December 2017 18:57
by jvdz
Have you checked the devicename whether it is the correct one and maybe you have 2 devices with the exact same name that could confuse LUA?
Jos
