need help for script - FAN Humidity Time
NoClaim
Domoticz version: 2.2284
Post by NoClaim »
I'm having a issue.... I don't understand LUA and Blockly isn't doing the trick :?
I have a centralized fan system (no on/off, but only 3 settings, low/medium/high [1/2/3/]) on a perilix connection
With the help of this forum I have setup a solution with KAKU and blockly which helps me to control the fan unit based on a time schedule
After a while I put a humidity sensor in the bathroom and setup blockly to switch the fan unit to position 3 (high) when the sensor shows 65% and below 65% turn to position 2. (between 12am and 7 am turn to position 1).
But.... when the humidity outside is default above 65% the unit stays in position 3 even if no-one is taking a shower.
So.... is it possible to create a script which looks at a delta of 2% whitin, lets say 3 minutes still keeping the blockly as it is or insert blockly into the new script....
NoClaim
Re: need help for script - FAN Humidity Time
Post by NoClaim »
No one??
Is my question impossible or is it because of the question?
please help :?:
Tomtommert
Domoticz version: 3.8631
Post by Tomtommert »
I've got a similar setup, but I'm using only one setting of my fan, high.
Check the code below, i did not write this myselfe, found it on the interwebs somehwere....
Hope it helps, works perfectly for me. :)
This script controls the humidity in a typical bathroom setting by detecting
relative rises in humidity in a short period.
Of course it requires a humidity sensor and a binary switch controlling a fan/ventilator.
(there is no provision for variable speed ventilators here!)
How it works (assuming the default constants as defined below):
Every 5 minutes a reading is done. Every reading is stored together
with the previous reading and is stored in two user variables (humidityTmin5 and humidityTmin10).
So it has two reading over the past 10 minutes.
It then takes the lowest of the two and compares it with the latest reading and
calculates a delta.
If the delta is 3 or higher (see constants) then the fan will be turned
on, it calculates the target humidity and the 'humidity-decrease program' is started (fanFollowsProgram=1).
From then on, every 5 minutes the current humidity is compared to the
stored target humidity. Basically if that target is reached, the fan is turned off
and the 'program' is ended.
Of course, it is possible that the target is never reached (might start raining outside
or whatever). Then there is a failsafe (FAN_MAX_TIME) after which the ventilator
will be turned off.
Also, it will detect if the ventilator is manually switched off during a program
or when it is switched on before the program starts.
Along the lines it prints to the log and sends notifications
but of course you can turn that off by removing those lines.
-- declare some constants
-- adjust to your specific situation
SAMPLE_INTERVAL = 5                -- time in minutes when a the script logic will happen
FAN_DELTA_TRIGGER = 2               -- rise in humidity that will trigger the fan
FAN_MAX_TIME = 300                  --  maximum amount of sample cycles the fan can be on,
                                    -- in case we never reach the target humidity
TARGET_OFFSET = -2                  -- ventilator goes off if target+offset is reached
                                    -- (maybe it takes too long to reach the true target due to wet towels etc)
FAN_NAME = 'Fan High'               -- exact device name of the switch turning on/off the ventilator
SENSOR_NAME = 'Badkamer Sensor'     -- exact device name of the humidity sensor
TEST_MODE = false                   -- when true TEST_MODE_HUMVAR is used instead of the real sensor
TEST_MODE_HUMVAR = 'testHumidity'   -- fake humidity value, give it a test value in domoticz/uservars
PRINT_MODE = false					-- when true wil print output to log and send notifications
if PRINT_MODE == false then
print('Fan control')
-- get the global variables:
-- this script runs every minute, humCounter is used to create SAMPLE_INTERVAL periods
humCounter = tonumber(uservariables['humCounter'])
humidityTmin5 = tonumber(uservariables['humidityTmin5'])                -- youngest reading
humidityTmin10 = tonumber(uservariables['humidityTmin10'])              -- oldest reading
targetFanOffHumidity = tonumber(uservariables['targetFanOffHumidity'])  -- target humidity
fanMaxTimer = tonumber(uservariables['fanMaxTimer'])
fanFollowsProgram = tonumber(uservariables['fanFollowsProgram'])        -- marker indicating that the
        -- decrease program is started
target = 0 -- will hold the target humidity when the program starts
-- get the current humidity value
if (TEST_MODE) then
    current = tonumber(uservariables[TEST_MODE_HUMVAR])
    current = otherdevices_humidity[SENSOR_NAME]
-- check if the sensor is on or has some weird reading
if (current == 0 or current == nil) then
    print('current is 0 or nil. Skipping this reading')
if PRINT_MODE == true then
        print('Current humidity:' .. current)
		print('targetFanOffHumidity:' .. targetFanOffHumidity)
		print('humidityTmin5: ' .. humidityTmin5)
		print('humidityTmin10: ' .. humidityTmin10)
		print('fanMaxTimer: ' .. fanMaxTimer)
		print('humCounter:' .. humCounter)
		print('fanFollowsProgram:' .. fanFollowsProgram)
-- increase cycle counter
humCounter = humCounter + 1
if (humCounter >= SAMPLE_INTERVAL) then
    if (humidityTmin5 == 0) then
        -- initialization, assume this is the first time
        humidityTmin5 = current
        humidityTmin10 = current
    humCounter = 0 -- reset the cycle counter
    -- pick the lowest history value to calculate the delta
    -- this also makes sure that two relative small deltas in the past 2*interval minutes are treated as one larger rise
    -- and therefore will still trigger the ventilator
    -- I don't want to use a longer interval instead because I want the ventilator to start as soon as possible
    -- (so rather after 5 minutes instead of after 15 minutes because the mirrors in the bathroom become kinda useless ;-)
    delta = current - math.min(humidityTmin10, humidityTmin5)
	print('Delta: ' .. delta)
    target = math.min(humidityTmin10, humidityTmin5) + TARGET_OFFSET
    -- shift the previous measurements
    humidityTmin10 = humidityTmin5
    -- and store the current
    if (otherdevices[FAN_NAME]=='Off' or (otherdevices[FAN_NAME]=='On' and fanFollowsProgram==0)) then
        -- either the fan is off or it is on but the decrease program has not started
        -- in that latter case we start the program anyway. This could happen if someone turns on the ventilator
        -- manually because he/she is about to take a shower and doesn't like damp mirrors.
        -- I don't do this because the ventilator removes heat from the bathroom and I want this to happen
        -- as late as possible ;-)
        if (fanFollowsProgram == 1 and otherdevices[FAN_NAME]=='Off') then
            -- likely someone turned off the ventilator while the program was running
            fanFollowsProgram = 0
        -- see if we have to turn it on
        if (delta >= FAN_DELTA_TRIGGER) then
            -- time to start the fan
            commandArray[FAN_NAME] = 'On'
            targetFanOffHumidity = target
            if (fanFollowsProgram == 1) then
                print('Ventilator was already on but we start the de-humidifying program')
            fanFollowsProgram = 1
            -- set the safety stop
            fanMaxTimer = FAN_MAX_TIME
            print('Rise in humidity. Turning on the vents. Delta: ' .. delta)
            print('Target humidity for turning the ventilator: ' ..targetFanOffHumidity)
            commandArray['SendNotification'] = 'Ventilator is on#The ventilator was activated at humidity level ' .. current .. '#0'
        if (fanMaxTimer > 0) then
            -- possible that someone started the ventialator manually
            fanMaxTimer = fanMaxTimer - 1
        if (fanFollowsProgram == 1) then -- not manually started
                -- ok, there is another FAN_DELTA_TRIGGER rise in humidity
                -- when this happen we reset the fanMaxTimer to a new count down
                -- because we have to ventilate a bit longer due to the extra humidity
				print('Another large increase detected, resetting max timer. Delta: ' .. delta)
            -- first see if it can be turned off
            if (current <= targetFanOffHumidity or fanMaxTimer==0) then
                commandArray[FAN_NAME] = 'Off'
                msg = ''
                if (fanMaxTimer == 0 and current > targetFanOffHumidity) then
                    msg = 'Target not reached but safety time-out is triggered.'
					print(msg)
                    msg = 'Target humidity reached'
					print(msg)
                print('Turning off the ventilator')
                msg = msg .. '\nTurning off the ventilator'
                targetFanOffHumidity = 0
                fanMaxTimer = 0
                -- reset history in this case.. we start all over
                -- Tmin10 is still in the 'ventilator=On'-zone
				commandArray['SendNotification'] = 'Ventilator is off#' .. msg .. '#0'
                -- we haven't reached the target yet
			   print('Humidity delta: ' .. delta)
    print('New values >>>>>>>>>>>')
    print('------ target: ' .. targetFanOffHumidity)
-- save the globals
commandArray['Variable:humCounter'] = tostring(humCounter)
commandArray['Variable:humidityTmin10'] = tostring(humidityTmin10)
commandArray['Variable:humidityTmin5'] = tostring(humidityTmin5)
commandArray['Variable:targetFanOffHumidity'] = tostring(targetFanOffHumidity)
commandArray['Variable:fanMaxTimer'] = tostring(fanMaxTimer)
commandArray['Variable:fanFollowsProgram'] = tostring(fanFollowsProgram)
