Domoticz can't send to /dev/udp
Posted: Tuesday 07 November 2017 17:18
I'v made a little bash script where I send codes to my milight lamps and they switch colour. When I use the netcat version it works:
But netcat can only send everything with one second delay so I want to use this script but domoticz can't run it. When I run it from the command line on my raspberry pi it works but when I attach this script to the on action from my group it doesn't:
Maybe something wrong with the relative path? Domoticz might run it from a different location?
echo -n -e "\x42\00\x55" | nc -u -q 1 xxx.xxx.xxx.xxx 8899
echo -n -e "\x40\x20\x55" | nc -u -q 1 xxx.xxx.xxx.xxx 8899
echo -n -e "\x40\xC0\x55" | nc -u -q 1 xxx.xxx.xxx.xxx 8899Code: Select all
echo -n -e "\x42\00\x55" > /dev/udp/xxx.xxx.xxx.xxx/8899
echo -n -e "\x40\x20\x55" > /dev/udp/xxx.xxx.xxx.xxx/8899
echo -n -e "\x40\xC0\x55" > /dev/udp/xxx.xxx.xxx.xxx/8899
