# PirCam Checker
# The goal of this script : catch the state of a PIR integrated in Dlink Camera
# when using the following API : http://IpCamAdress:port//config/io.cgi
# the API return in1=Off /r/n out1=on"
# this means the setup of the duration the output of the camera need to be twice longer compared to the heartbeat to be sure to capture all the changes of the ouput
# in1 can be equal to on or off
# out1 can be equal to on or off
# the API is under basic Auth
# At the end this script would be generic to retrieve some string from an URL to set a switch on or off
# tis script is based on :
# Goolgle Home page example
# Author: Dnpwwo, 2017
# Demonstrates HTTP connectivity.
# After connection it performs a GET on www.google.com and receives a 302 (Page Moved) response
# It then does a subsequent GET on the Location specified in the 302 response and receives a 200 response.
<plugin key="httpt" name="httpt" author="Dnpwwo" version="1.1.0" externallink="https://www.google.com">
<params>
<param field="Address" label="IP Address" width="200px" required="true" default="192.168.1.14"/>
<param field="Port" label="Port" width="30px" required="true" default="1028"/>
<param field="Username" label="Username" width="200px" required="true" default="admin"/>
<param field="Password" label="Password" width="200px" required="true" default=""/>
<param field="Mode1" label="Update the device even the state is the same" width="400px">
<options>
<option label="Yes" value="Yes"/>
<option label="No" value="False" default="No" />
</options>
</param>
<param field="Mode2" label="String to set the device On" width="75px"/>
<param field="Mode3" label="String to set the device Off" width="75px"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="true" />
<option label="Logging" value="File"/>
</options>
</param>
</params>
</plugin>
import Domoticz
import base64
class BasePlugin:
httpConn = None
runAgain = 6
def __init__(self):
return
def onStart(self):
if Parameters["Mode6"] == "Debug":
Domoticz.Debugging(1)
DumpConfigToLog()
# create the mandatory child device if it does not yet exist
if 1 not in Devices:
Domoticz.Device(Name="PIR_CAM", Unit=1, TypeName="Switch").Create()
Domoticz.Log("Device created.")
self.httpConn = Domoticz.Connection(Name="HTTP Test", Transport="TCP/IP", Protocol="HTTP", Address=Parameters["Address"], Port=Parameters["Port"],)
self.httpConn.Connect()
Domoticz.Heartbeat(4)
def onStop(self):
Domoticz.Log("onStop - Plugin is stopping.")
def onConnect(self, Connection, Status, Description):
Domoticz.Log("onConnect called")
if (Status == 0):
#base64 string for Basic Auth
credentials = ('%s:%s' % (Parameters["Username"], Parameters["Password"]))
encoded_credentials = base64.b64encode(credentials.encode('ascii'))
bas=encoded_credentials.decode("ascii")
Domoticz.Debug("Device connected successfully."+bas)
sendData = { 'Verb' : 'GET',
'URL' : '/config/io.cgi',
'Headers' : { 'Content-Type': 'text/xml; charset=utf-8', \
'Connection': 'keep-alive', \
'Accept': 'Content-Type: text/html; charset=UTF-8', \
'Host': Parameters["Address"]+":"+Parameters["Port"], \
'Authorization':'Basic '+bas, \
'User-Agent':'Domoticz/1.0' }
Connection.Send(sendData)
else:
Domoticz.Log("Failed to connect ("+str(Status)+") to: "+Parameters["Address"]+":"+Parameters["Port"]+" with error: "+Description)
def onMessage(self, Connection, Data):
#DumpHTTPResponseToLog(Data)
strData = Data["Data"].decode("utf-8", "ignore")
Status = int(Data["Status"])
#Domoticz.Log(strData)
PosOn=strData.find(Parameters["Mode2"])
PosOff=strData.find(Parameters["Mode3"])
if ( ( PosOn>-1 and Devices[1].sValue=="Off" and Parameters["Mode1"]=="No") or ( (PosOn>-1 and Parameters["Mode1"]=="Yes") ) ) :
UpdateDevice(1,1,"On")
Domoticz.Log("device1="+str(Devices[1].sValue))
if ( (PosOff>-1 and Devices[1].sValue=="On" and Parameters["Mode1"]=="No") or ( (PosOff>-1 and Parameters["Mode1"]=="Yes") ) ) :
UpdateDevice(1,0,"Off")
if (Status == 200):
Domoticz.Debug("Good Response received.")
# no more needed
#self.httpConn.Disconnect()
# below to delete
elif (Status == 302):
Domoticz.Log("Device returned a Page Moved Error.")
'URL' : Data["Headers"]["Location"],
'User-Agent':'Domoticz/1.0' },
elif (Status == 400):
Domoticz.Error("Device returned a Bad Request Error.")
elif (Status == 500):
Domoticz.Error("Device returned a Server Error.")
else:
Domoticz.Error("Device returned a status: "+str(Status))
def onCommand(self, Unit, Command, Level, Hue):
Domoticz.Debug("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
if Command=="On":
Devices[1].Update(1, "1")
if Command=="Off":
Devices[1].Update(0,"0")
#check for debug
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
# no need either this appears in the log : Error: CConnection_disconnect, disconnection request from 'salon' ignored. Transport does not exist.
#def onDisconnect(self, Connection):
#Domoticz.Log("onDisconnect called for connection to: "+Connection.Address+":"+Connection.Port)
def onHeartbeat(self):
Domoticz.Log("onHeartbeat called")
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onConnect(Connection, Status, Description):
global _plugin
_plugin.onConnect(Connection, Status, Description)
def onMessage(Connection, Data):
global _plugin
_plugin.onMessage(Connection, Data)
def onCommand(Unit, Command, Level, Hue):
global _plugin
_plugin.onCommand(Unit, Command, Level, Hue)
def onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile):
global _plugin
_plugin.onNotification(Name, Subject, Text, Status, Priority, Sound, ImageFile)
# def onDisconnect(Connection):
# global _plugin
# _plugin.onDisconnect(Connection)
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def LogMessage(Message):
if Parameters["Mode6"] == "File":
f = open(Parameters["HomeFolder"]+"http.html","w")
f.write(Message)
f.close()
Domoticz.Log("File written")
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
return
def DumpHTTPResponseToLog(httpDict):
if isinstance(httpDict, dict):
Domoticz.Log("HTTP Details ("+str(len(httpDict))+"):")
for x in httpDict:
if isinstance(httpDict[x], dict):
Domoticz.Log("--->'"+x+" ("+str(len(httpDict[x]))+"):")
for y in httpDict[x]:
Domoticz.Log("------->'" + y + "':'" + str(httpDict[x][y]) + "'")
else:
Domoticz.Log("--->'" + x + "':'" + str(httpDict[x]) + "'")
def UpdateDevice(Unit, nValue, sValue):
# Make sure that the Domoticz device still exists (they can be deleted) before updating it
if (Unit in Devices):
#if (Devices[Unit].nValue != nValue) or (Devices[Unit].sValue != sValue):
Devices[Unit].Update(nValue, str(sValue))
Domoticz.Log("Update "+"' ("+Devices[Unit].Name+") "+":'"+str(sValue))
return
