Lost ID and Type id and configuration part on Node Management Topic is solved
boboland
Post by boboland »
Just as info. Domoticz lost the ID and the Type ID for some Fibaro devices. Why ? I don't know.
So also the configuration part is no more present for those devices :o
After some clicks.. i found out that we can do a refresh of those devices...
Setup->Hardware->Setup->Control Panel (OpenzWave) -> Click on the device without Product name (red) -> Controller (drop down menu) -> Refresh node info -> Go
Everything re-appears on node management tab :D
lost
Re: Lost ID and Type id and configuration part on Node Management
Post by lost »
boboland wrote: Saturday 04 November 2017 18:37 Hi,
Thanks for the tip, it would have saved me several re-inclusions (& losing some sensors statistics until I notices the "replace" tab) on my recent domotics update from old-stable!
Got several devices with ID at 0/0 after the update :o(
gizmocuz
Post by gizmocuz »
This problem was caused by a recent pull request that caused all http calls to be executed twice
A new build is in the make that should be available within the hour (#8701)
This will fix this issue
