Problem with EASY ESP
Posted: Tuesday 31 October 2017 14:28
Hi All,
I´m using an Raspi 3, Domoticz Beta 3.8662 Build hash ddb94219 2017-10-30
Problem: I´m using a SONOF 4ch. Relay with ESPEASY and also an WEMOS Mini ESP8266 with 4 relays. The SONOFF is flashed to v2.0.0-dev12 and the other is flashed to Stable 120.
Both are showing the same issue: More or less often a click on the virtual switch will cause this error:
2017-10-31 14:02:35.895 User: Admin initiated a switch command (40/Carport Lichterkette/On)
2017-10-31 14:02:36.900 (ESP) Light/Switch (Carport Lichterkette)
2017-10-31 14:02:47.104 Error: Error opening url: http://192.168.178.57/control?cmd=GPIO,12,1
The light is not going on. If i retry the command in Domoticz, nothing will happen, only the same printout in the log.
But if i take the IP Adress http://192.168.178.57/control?cmd=GPIO,12,1 in a normal browser, the relays will do there job, and this every time. I tryed to use an „on delay“ inside the virtual switch, but thats not the solution. Looks like the command is not going out of Domoticz.
I also habe running a 2nd Domoticz on a Synology with V3.8153 and the same 4 ch. Relay and the same EASYESP (v2.0.0-dev12) and there i have no erros, no issues.
May be someone has an idea or the error is inside the beta on the Raspi 3.
Best Regards
Peter
Best Regards
Peter
