Setting Fibaro Wall Plug Gen5 Switch State
Posted: Saturday 28 October 2017 21:59
by Wolfgang
Hi ,
I've got a strange problem with a LUA Script on Domoticz 3.8153 .
The Script should set the plug state on
if the Plug "Leistung Steckdose Wohnzimmer Entertainment" has more power than 90 Watt
and the
room brightness of the brightness Sensor is lower than 200 Lux
and the
light on the ceiling is not switched to on.
The script is killing the plug if I set the state with the Content of the variable target_state_stehlampe ( which is On or Off )
but is currently working with the below solution.
Any suggestions why the plug is not responding anymore if the content of the variable is written to the commandarray ?
Below the code of the lua script :
local debug
if ( uservariables["GlobalDebug"] == "On" ) then
    debug = true
    debug = false
local time = os.date("*t")
local energy_level = 90
local brightness_level = 110
function timedifference (s)
  year = string.sub(s, 1, 4)
  month = string.sub(s, 6, 7)
  day = string.sub(s, 9, 10)
  hour = string.sub(s, 12, 13)
  t1 = os.time()
  return difference
local room_brightness = otherdevices_svalues["Helligkeit Sensor Balkon Aussen"]
local state_stehlampe = otherdevices['Licht Wohnzimmer Stehlampe']
local target_state_stehlampe = ""
if not room_brightness or room_brightness == ''  then
    if debug == true then
        print ("Raum Helligkeit       : Kein Wert verfügbar" )
    room_brightness = "200"
local tv_energy         = otherdevices_svalues["Leistung Steckdose Wohnzimmer Entertainment"]
local state_licht_decke = otherdevices['Niveau Licht Wohnzimmer']
    print ("WoZi Energie        : " .. tostring(tonumber(tv_energy )))
    print ("WoZi Energielevel   : " .. energy_level )
    print ("WoZi Dimmer State   : " .. state_licht_decke )
    print ("WoZi Helligkeit     : " .. room_brightness )
    print ("WoZi Stehlampe      : " .. state_stehlampe )
if (tonumber(room_brightness) < brightness_level ) then
    target_state_stehlampe = 'On'
        print ("Raum zu dunkel    : Stehlampe ein" )
if (tonumber(tv_energy) < tonumber(energy_level) ) then
    target_state_stehlampe ='Off'
        print ("Leistung Entertainment zu klein    : Stehlampe aus" )
if (tonumber(room_brightness) > brightness_level ) then
        print ("Raum zu Hell    : Stehlampe aus" )
if (state_licht_decke ~= 'Off' ) then
            print ("Deckenbeleuchtung ein erkannt" )
            print ("Stehlampen Status         : " .. state_stehlampe )
            print ("Stehlampe State gewünscht : " .. target_state_stehlampe )
    target_state_stehlampe = 'Off'
        print ("Deckenbeleuchtung ein   : Stehlampe aus" )
if otherdevices['Licht Wohnzimmer Stehlampe'] ~= target_state_stehlampe then
--    not working
--     commandArray['Licht Wohnzimmer Stehlampe'] = target_state_stehlampe
        if (target_state_stehlampe == 'On') then
              commandArray['Licht Wohnzimmer Stehlampe'] = 'On'
        if (target_state_stehlampe == 'Off') then
              commandArray['Licht Wohnzimmer Stehlampe'] = 'Off'
            print ("Stehlampe Wohnzimmer State Change    : " .. target_state_stehlampe )
            print ("Stehlampe Wohnzimmer State Change not needed   : " .. target_state_stehlampe )
