Authorization Problems
Ghost
Post by Ghost »
Hello Friends,
I need help with Authorization using the API URL on the current beta version of Domoticz. I have spent lots of hours with that but I just do not succeed in get authorized.
The quite simple Python script I try to get run is:
#!/usr/bin/python
import sys
import urllib
import urllib2
import base64
sensor_idx  = 16
url = "http://192.168.178.32:8080"
url_json = url + "/json.htm"
cpuTemp = int(open('/sys/class/thermal/thermal_zone0/temp').read()) / 1000.0
cmd = url_json + "?" + "type=command&param=udevice&idx=" + str(sensor_idx) + "&nvalue=0&svalue=" + str(cpuTemp)
print cmd
base64string = base64.encodestring('%s:%s' % ("LOGIN", "PASSWORD")).replace('\n', '')
request = urllib2.Request(cmd)
request.add_header("Authorization", "Basic %s" % base64string)
response = urllib2.urlopen(request)
print response.read()
192.168.178.32 is the IP of the Raspberry Pi 3 on which Domoticz is running.
The user LOGIN is added on "Setup" -> "More options" -> "Edit users" and has admin rights on all devices.
In "Setup" -> "Settings" I have tried out a lot of settings. Allowed everything. Entered different credentials and cleared them completely. Added 192.168.178.32 and 127.0.0.1 (and submasks) to "Local Networks (no username/password):"
But nothing helps! When i type on SSH:
sudo python cpu_temperature.py
I get:
http://192.168.178.32:8080/json.htm?type=command&param=udevice&idx=1&nvalue=0&svalue=48
  File "cpu_temperature.py", line 33, in <module>
  File "/usr/lib/python2.7/urllib2.py", line 154, in urlopen
    return opener.open(url, data, timeout)
  File "/usr/lib/python2.7/urllib2.py", line 435, in open
    response = meth(req, response)
  File "/usr/lib/python2.7/urllib2.py", line 548, in http_response
    'http', request, response, code, msg, hdrs)
  File "/usr/lib/python2.7/urllib2.py", line 473, in error
    return self._call_chain(*args)
  File "/usr/lib/python2.7/urllib2.py", line 407, in _call_chain
    result = func(*args)
  File "/usr/lib/python2.7/urllib2.py", line 556, in http_error_default
    raise HTTPError(req.get_full_url(), code, msg, hdrs, fp)
urllib2.HTTPError: HTTP Error 401: Unauthorized
The other way of authorization according to Wiki (with URL containing encoded User and Password) produces the same result.
When I type the link (http://192.168.178.32:8080/json.htm?typ ... &svalue=48) in most cases everything works fine. But sometimes I get "401 Unauthorized" too.
I have tried to delete and install Domoticz again. I have not changed any settings after the installation. And it worked! With SSH and as crontab. But only till a restart of Raspberry Pi 3. Afterwards it is the same: "401 Unauthorized"...
I would be very grateful for every hint.
kofec
Re: Authorization Problems
Post by kofec »
I have the same problem
emme
Domoticz version: latest
Post by emme »
have you tried:
url = "http://user:[email protected]:8080"
or enter the ip address in the whitelist unser settings?
if the script runs on the same hardware of domoticz try using 127.0.0.1 as ip address
"We always done this way"
Geko
Post by Geko »
I have the same problem.
Even if i directly type the [url]http://username:password@ip:port>/json.htm?api-call[/url] to the browser I get an Err back....
Is this a bug?
Andy
dobber
Domoticz version: Beta..
Post by dobber »
I'm seeing the same thing now. json api sending unauthorized until I go in to settings and press "save". After this api works great until next reboot.
