Creating devices for included node Topic is solved
cincuranet
Hi, I included new node on my Aeotec Z-Stick using the button (not via Domoticz), because it was too far from it and I had to get physically closer. Now I see the node in the list in Hardware, but I don't have any new devices in Devices. Is there a way to create these? I can control the node from OZW Control Panel just fine. So I think I "just" need to somehow create these devices.
Skippiemanz
- Domoticz version: 4.10233
Re: Creating devices for included node
Try sending the heal command trough domoticz. Or wake up the device. The devices should appear in the Un used tabcincuranet wrote:Hi, I included new node on my Aeotec Z-Stick using the button (not via Domoticz), because it was too far from it and I had to get physically closer. Now I see the node in the list in Hardware, but I don't have any new devices in Devices. Is there a way to create these? I can control the node from OZW Control Panel just fine. So I think I "just" need to somehow create these devices.
cincuranet
The device is always on ("Z-Wave+ node Always On Slave"). I tried clicking on "Heal" button now. But even after few minutes not a single device appeared.
cincuranet
Just to be sure, I also restarted my Raspberry Pi and for a while I saw "Not all Nodes have been Queried yet, OpenZWave not fully initialized yet!". But no new devices after that.
cincuranet
Ahh, finally solved it. I enabled "Accept new Hardware Devices" and then rebooted my Raspberry Pi. New devices appeared then.
Not sure whether having "Accept new Hardware Devices" off makes a "security" (or any other) difference, but I keep it that way.
