Prerequisites: dzVents version 2.3.1 or higher.
Documentation is the code. Some notes though ...
You should create a virtual switch device to control the privacy masks.
Each camera is defined in the webCams table. Each entry has a ['switchProfiles'] key. It can be a boolean or a function.
['switchProfiles'] = true The camera will switch profiles according to the timer triggers defined in TIME_SWITCH_DAY_PROFILE and TIME_SWITCH_NIGHT_PROFILE
['switchProfiles'] = false Profile switching will not occur.
['switchProfiles'] = function Define a function that either returns "day" or "night". Make sure to also add devices you use in your function as dzVents device triggers (if needed). (Named LightingMood in the example code below)
This script will need some customization and changes to work on your system. It's not intended to work "as is" for everyone. If you like it, copy it and make it yours. Don't try this script unless you are quite familiar with Lua scripting and dzvents. If You have IP camera related questions you should ask them on IP Cam Talk.
dahuaCams.lua, a Domoticz dzVents Script for Dahua IP Cameras
local SEC_MASK_DEV_NAME = 'SEC MASK' -- The name of the device in your system
local TIME_INTERVAL = 'every 15 minutes'
local TIME_SWITCH_DAY_PROFILE = '5 minutes before sunrise'
local TIME_SWITCH_NIGHT_PROFILE = '5 minutes after sunset'
local SCRIPT_VERSION = '1.0.0'
active = true,
logging = {
level = domoticz.LOG_INFO, -- Select one of LOG_DEBUG, LOG_INFO, LOG_ERROR, LOG_FORCE to override system log level
marker = 'dahuaCams V'..SCRIPT_VERSION
devices = {SEC_MASK_DEV_NAME, 'LightingMood'},
timer = {TIME_INTERVAL, TIME_SWITCH_DAY_PROFILE, TIME_SWITCH_NIGHT_PROFILE}
data = {
camsLastProfile = {initial={}}, odTemp = {initial=-273.15}, odHum = {initial=-1}, idTemp = {initial=-273.15}, idHum = {initial=-1}
execute = function(domoticz, device, triggerInfo)
local CAM_DOMAIN = 'somedomain.com' --
local camLogin = 'admin:XXXPASSYYY'
local webCams = {
['cam-driveway'] = {['enabled'] = true, ['PTZ'] = false,['outDoors'] = true, ['useSecMask'] = true, ['switchProfiles'] = true,},
['cam-living-room'] = {['enabled'] = true, ['PTZ'] = false, ['outDoors'] = false, ['useSecMask'] = false, ['switchProfiles'] =
if domoticz.devices('Day State').text == 'night'
and domoticz.devices('LightingMood').text == 'off' then
return 'night'
return 'day'
end},
['cam-main-entrance'] = {['enabled'] = true, ['PTZ'] = false, ['outDoors'] = true, ['useSecMask'] = true, ['switchProfiles'] = true},
-- Make sure that there is a saved day/night profile state in the array for each camera
local camsLastProfile = domoticz.data.camsLastProfile
for key, _value in pairs(webCams) do
if camsLastProfile[key] == nil then
camsLastProfile[key] = 'unknown'
if triggerInfo.type == domoticz.EVENT_TYPE_DEVICE then
if device.name == SEC_MASK_DEV_NAME then
local toState = tostring(device.active)
for hostName, camConfig in pairs(webCams) do
if camConfig.enabled and camConfig.useSecMask then
domoticz.log('Setting security mask for camera: '..hostName..' to: '..toState, domoticz.LOG_INFO)
domoticz.openURL(camLogin..'@'..hostName..'.'..CAM_DOMAIN..'/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].Covers[0].EncodeBlend='..toState..'&VideoWidget[0].Covers[1].EncodeBlend='..toState..'&VideoWidget[0].Covers[2].EncodeBlend='..toState..'&VideoWidget[0].Covers[3].EncodeBlend='..toState)
-- A device event occurred. We need to go through all the cameras that have
-- a function defined for switching between day/night mode. Cameras that have a boolean
-- for switching between day/night mode are not handled here (See timer triggerd events)
domoticz.log('A device event for '..device.name..' occurred that might cause shifting day/night profile', domoticz.LOG_INFO)
local switchProfiles = (type(camConfig.switchProfiles) == 'function') and camConfig.switchProfiles(domoticz, device, triggerInfo) or false
if camConfig.enabled and switchProfiles and camsLastProfile[hostName] ~= switchProfiles then
camsLastProfile[hostName] = switchProfiles -- Saving state
if camConfig.PTZ then
domoticz.log('Switching PTZ cam: '..hostName..' to use '..switchProfiles..' profile', domoticz.LOG_INFO)
local newValue = switchProfiles == 'day' and '1' or '2'
domoticz.openURL(camLogin..'@'..hostName..'.'..CAM_DOMAIN..'/cgi-bin/configManager.cgi?action=setConfig&VideoInMode[0].Config[0]='..newValue)
domoticz.log('Switching IPC cam: '..hostName..' to use '..switchProfiles..' profile', domoticz.LOG_INFO)
local newValue = switchProfiles == 'day' and '0' or '3'
domoticz.openURL(camLogin..'@'..hostName..'.'..CAM_DOMAIN..'/cgi-bin/configManager.cgi?action=setConfig&VideoInOptions[0].NightOptions.SwitchMode='..newValue)
elseif triggerInfo.type == domoticz.EVENT_TYPE_TIMER then
if triggerInfo.trigger == TIME_INTERVAL then
-- Outdoor and indoor Temp and humidity for camera OSD
local odTemp = domoticz.round(domoticz.devices('F750 Outdoor Temp.').temperature, 1)
local odHum = domoticz.round(domoticz.devices('Vinden C + RH').humidity, 0)
local idTemp = domoticz.round(domoticz.devices('WH2600 Indoor TempHum').temperature, 1)
local idHum = domoticz.round(domoticz.devices('WH2600 Indoor TempHum').humidity, 0)
if (odTemp ~= domoticz.data.odTemp) or (odHum ~= domoticz.data.odHum) then
domoticz.data.odTemp = odTemp
domoticz.data.odHum = odHum
local osdText = string.gsub(domoticz.urlEncode(tostring(odTemp)..'°C, '.. tostring(odHum)..'% RH'), '+', '%%20')
if camConfig.enabled and camConfig.outDoors then
domoticz.log('Cam: '..hostName..': '..tostring(odTemp)..'°C, '.. tostring(odHum)..'% RH', domoticz.LOG_INFO)
domoticz.openURL(camLogin..'@'..hostName..'.'..CAM_DOMAIN..'/cgi-bin/configManager.cgi?action=setConfig&VideoWidget[0].CustomTitle[1].Text='..osdText)
if (idTemp ~= domoticz.data.idTemp) or (idHum ~= domoticz.data.idHum) then
domoticz.data.idTemp = idTemp
domoticz.data.idHum = idHum
local osdText = string.gsub(domoticz.urlEncode(tostring(idTemp)..'°C, '.. tostring(idHum)..'% RH'), '+', '%%20')
if camConfig.enabled and not camConfig.outDoors then
domoticz.log('Cam: '..hostName..': '..tostring(idTemp)..'°C, '.. tostring(idHum)..'% RH', domoticz.LOG_INFO)
-- Toggling day/night mode for cameras that has ['switchProfiles'] = true (Must be a boolean and set to true)
elseif triggerInfo.trigger == TIME_SWITCH_DAY_PROFILE or triggerInfo.trigger == TIME_SWITCH_NIGHT_PROFILE then
domoticz.log('Time for switching cameras to use the day/night profile', domoticz.LOG_INFO)
--local switchProfiles = (type(camConfig.switchProfiles) == 'function') and camConfig.switchProfiles(domoticz, device, triggerInfo) or camConfig.switchProfiles
local switchProfiles = (type(camConfig.switchProfiles) == 'function') and false or camConfig.switchProfiles
local newState = (triggerInfo.trigger == TIME_SWITCH_DAY_PROFILE and 'day' or 'night')
if camConfig.enabled and switchProfiles and camsLastProfile[hostName] ~= newState then
camsLastProfile[hostName] = newState -- Saving state
domoticz.log('Switching PTZ cam: '..hostName..' to use '..newState..' profile', domoticz.LOG_INFO)
local newValue = triggerInfo.trigger == TIME_SWITCH_DAY_PROFILE and '1' or '2'
domoticz.log('Switching IPC cam: '..hostName..' to use '..newState..' profile', domoticz.LOG_INFO)
local newValue = triggerInfo.trigger == TIME_SWITCH_DAY_PROFILE and '0' or '3'
