433Mhz + Lua + Mysensors crash Domoticz?
Posted: Wednesday 25 October 2017 12:41
Software V.38631 (same problem with V3.8635)
Raspberry PI 2
My sensors V 2.1.1
RFLink V46
I hope someone can help me with my problem
My setup:
I have a a 433Mhz wall switch witch can only send "on" command and my lights in living room is using mysensors relay.
In between is Lua script:
I have a strange problem with my setup almost always when i press the button on remote than mysensors gateway is restarting and not responding for ~5 minutes. From time to time its working fine with no problems.
My first action was too replace the power adapter from 5v 2A to 5v 4A but it did't help. The problem appears only in compilation with lua script in other cases it is working with no problem.
Complete reinstall with db restore didn't help
Raspberry PI 2
My sensors V 2.1.1
RFLink V46
My setup:
if (devicechanged['knop_bank_1'] == 'On') then
if (otherdevices['Woonkamer licht 1'] == 'Off') then
commandArray['Woonkamer licht 1']='On'
commandArray['Woonkamer licht 1']='Off'
commandArray['knop_bank_1']='Off'
return commandArrayI have a strange problem with my setup almost always when i press the button on remote than mysensors gateway is restarting and not responding for ~5 minutes. From time to time its working fine with no problems.
