Hello, i want to implement a monitoring script for check the state of my xiaomi vacuum.
I've installed the plugin and it works, in the device 'VACUUM' the SValues is CLEANING-CHARGING-PAUSED and i want to insert this value in a local variable and compare the state later such:
FIRST:
local STATE == domoticz.devices('VACUUM').Svalues
LATER:
if domoticz.devices('VACUUM').Svalues =~ STATE then
domoticz.notify........
any help how to get the Svalues? I know how to read the .state (that is ON when cleaning but OFF when both is in pause or charging so it's not usefull)...
Thanks in advance, cheers
read SValues content and put in a local variable
dannybloe
Re: read SValues content and put in a local variable
You can read the rawData attribute as that should hold all the values. But it is better to create a deviceAdapter for this kind of device eventually.
For now you can dump all the attributes known to dzVents: myDevice.dump(). It will dump it's attributes to the Domoticz log.
And... you don't have to use uservariables. I'd use dzVents persistent variable support (see docs).
