Weather station GAL WS-1501 incorrectly shows negative temperatures.
Posted: Sunday 22 October 2017 13:06
Version: 3.8153 stable
Platform: NAS Synology DS116 (DSM 6.1.3-15152 )
Plugin/Hardware: RFLink Gateway with LAN interface Version: 47.8
Hello!
With the weather station GAL WS-1501.
RFLink defines how "InoValley_SM200". In the summer it works perfectly. At temperatures below zero, the temperature is incorrect. With the real -0.1, it shows -101.2 С
In logfile "RFLink: 20;8B;InoValley_SM200;ID=02b2;TEMP=83FE;"
As the temperature decreases, the values increase! At minus 1.2 degrees, the values in the RFLink protocol are "TEMP = 83F4;"
Can I correct the negative temperatures on this sensor?
Thank you!
Hello!
Thank you!
