Double Xiaomi Gateway
Andree
Post by Andree »
Hi to all, i've follow the guide in wiki and i've add a second gateway in my configuration.
The new Gateway have been add and the devices attached with this new Gateway have been recognized by domoticz (with the name of OLD gateway don't know if this is normal)
The problem is that: since I added the second smart plugs (connected to the first one) sometimes they do not respond and the lights and sounds of the two Gateway almost never work.
I find these errors in the log when I try to activate a smart plug and it does not work
2017-10-18 12:31:36.332 User: Admin initiated a switch command (435/Power Cam Stufa/Off)
2017-10-18 12:31:36.488 Error: XiaomiGateway: unable to write command - Invalid Key
2017-10-18 12:31:36.488 XiaomiGateway: SendMessageToGateway failed on first attempt, will try again
2017-10-18 12:31:36.754 Error: XiaomiGateway: unable to write command - Invalid Key
Thx
Andree
Re: Double Xiaomi Gateway
Post by Andree »
up!
