Monitor memory usage - curl command results in "401 Unauthorized"
All kinds of 'OS' scripts
Feddan
Post by Feddan »
I'm trying to follow this guide:
https://www.domoticz.com/wiki/Monitor_memory_usage
It didn't work but after replacing "grep telegram-cli" with "grep domoticz" I at least got it to print out the current memory usage in the terminal. But when I execute the following command:
curl "http://192.168.1.243:8080/json.htm?type=command&param=udevice&idx=128&nvalue=0&svalue=2.5"
I get:
<html><head><title>Unauthorized</title></head><body><h1>401 Unauthorized</h1></body></html>
Any ideas what I've done wrong?
Feddan
Re: Monitor memory usage - curl command results in "401 Unauthorized"
Post by Feddan »
I solved it by adding &username=AAA&password=BBB
where AAA is the encoded username and BBB is the encoded password. I used this webpage to encode them: https://www.base64encode.org/
More information regarding this is available here: https://www.domoticz.com/wiki/Domoticz_ ... horization
So this is the updated command (Username and Password have been changed):
curl "http://192.168.1.243:8080/json.htm?username=ZG9ua2V5&password=ZnVja2Vy&type=command&param=udevice&idx=128&nvalue=0&svalue=0"
