LUA script for logging
Slinkos
Domoticz version: 3.4834
Post by Slinkos »
I have bought a PIR (Motion Sensor) and I want to monitor if it has false positives. So I was thinking to create a lua script that makes a separate log file somewhere, whenever my PIR is on and I am not home. It doesn't have to be readable within Domoticz, I'm fine with setting up a SSH connection and cat the logfile.
So I was thinking something like:
if (devicechanged['PIR'] == 'On' and otherdevices['Home'] == 'Off') then
file = io.open("home/pi/domoticz/scripts/motionlog.txt", "w")
file:write(os.time "Motion detected while not home")
file:close()
But my experience in LUA is zero, so this will probably be full with mistakes. I don't see any errors, but I also don't see any file being created in the folder specified. The event doesn't even seem to be triggered.
I hope someone can help. thanks in advance.
jannl
Domoticz version: 2026.1.x
Re: LUA script for logging
Post by jannl »
Not sure why you want to do that. I never have had any false positives on any of my pir's. X10 or zwave.
Slinkos
Post by Slinkos »
Well, I have
jannl
Post by jannl »
I think you better find out why you have false positives. May be bad location of the pir. Sudden heat flows or so
Slinkos
Post by Slinkos »
Please just answer my question, this is not helping me. Logging it may help me finding out what causes it.
jannl
Post by jannl »
Logging is already present on Domoticz
Slinkos
Post by Slinkos »
But not the way I want it. If you don't know the answer that's fine. Then I hope someone else can reply.
