Group on/off
Posted: Monday 16 October 2017 19:50
by febalci
I am using the Group Switch in Scenes for all the rollershutters. If i press down off, all shutters close and for on all shutters open. What i wonder is, is there a status check mechanism in Groups; like when pressing "Off" does the Group switch send all shutters an "Off" message whether they are open or closed, or only the ones which are already or partially open? I do not want to create a zwave network traffic for all the switches, or should i use a script which checks the status of the shutters, instead of using a group?
Re: Group on/off
Posted: Friday 20 October 2017 9:38
by febalci
Let me answer my own question; just found out that Group switches send all members of the group on/off messages, whether they are on or off. So instead of using group switch i used an "if" status check one by one and then send off messages accordingly.
Re: Group on/off
Posted: Friday 20 October 2017 9:49
by Maes
Are you using the Fibaro FGRM222 ?
I have 12 of them and when I put them in a group I could turn it "off" (so everything closed) but I wasn't able to press the button again to make them go "on".
So, my group only allowed the closing...
To resolve this I created 2 scenes. 1 for close and 1 for open.
My fibaro's are configured as blinds percentage inverted. Yours too ?
Re: Group on/off
Posted: Friday 20 October 2017 9:52
by emme
do not worry about flooding the zWave network, you will never mess it!
(well.. maybe only if you start playing with pollings
...by my opinion, you take much more server resources and CPU load with a script that query the device and issue the off command if needed, than issue the command by a group
Re: Group on/off
Posted: Friday 20 October 2017 9:53
by emme
Maes wrote: Friday 20 October 2017 9:49
that's not good...
I have a group of 6 and they go on and off correctly.....
can you post a screenshot of you group configuration?
Re: Group on/off
Posted: Friday 20 October 2017 9:56
by Maes
Do you also have them configured as blinds percentage
inverted?
This is a screenshot of my scene. I don't have the group anymore.
Re: Group on/off
Posted: Friday 20 October 2017 10:14
by febalci
febalci wrote: Friday 20 October 2017 9:38
I use Qubino ZMNCHD flush shutter modules, 11 of them. They are all in "Blinds Inverted Percentage". Group On and Off works as expected, no problems there. However when i make a "Group Off" Request, Imperihome loses status. There's no problem with the "Group On" function.
