I try to pair a Milight FUT103 via RFLink (R47), unsuccessful so far.
RFLink works as when I create a device in domoticz by learning via Zone control or iBOX I can control te bulp.
However if I try to pair it directly I cannot:
I tried per instructions for this bulp:
10;MiLightv1;20F746;01;34BC;PAIR;
Nothings happens, I then tried the commands which are not intended for this bulp and something happens with:
10;MiLightv1;F746;01;34BC;PAIR;
It flashes 2x green and the third time it becomes solid white. It does this for each other id I use, but then after I cannot do anything. No on/off, and also no UNPAIR.
Anyone already a FUT103 GU10 RGB+CCT device paired ?
Help is appreciated
Peter
How to pair milight FUT103 GU10 RGB+CCT
Milifax
- Domoticz version: 2024.4
Re: How to pair milight FUT103 GU10 RGB+CCT
Contact Stuntteam directly. You'll find him on the forum here or at Rflink forum. They are working on 's New release and he has a solution for you.
Sijpkes
Thanks, I will do so.
