Problem retrieving devices! after enabling python plugin
Posted: Wednesday 11 October 2017 11:09
I have problem with one of my plugin (https://github.com/lrybak/domoticz-storm-report).
A while after enabling my plugin, Devices section won't load - Problem retrieving devices! alert message appears
The Devices sections doesn't load becouse of the problem with JSON parsing
I found that for some reason, after enabling my plugin some other devices (wunderground idx 168 and 169) are being changed.
After that JSON for Device section is malformed and refuse to load (/json.htm?type=devices&displayhidden=1&displaydisabled=1&filter=all&used=all)
Please see step I performed to reproduce this issue
I used v3.8564 but the issue exists on stable v3.8153 as well
Screens and log zipped: https://www.dropbox.com/s/jqswib3qgbtaj ... e.zip?dl=0
Hardware view
Section Devices display correctly
Data in DeviceStatus table (idx 168 and 169)
Enable my plugin + domoticz restart
Hardware view - plugin enabled
Device view - Problem retrieving devices!
Bad formated float value in json (/json.htm?type=devices&displayhidden=1&displaydisabled=1&filter=all&used=all)
Data in DeviceStatus table (idx 168 and 169) changed
Hardware table
I disabled plugin and did domoticz restart
sqlite> Update Hardware set Enabled=0 where Extra='domoticz-storm-report';
After a while Devices sections has appeared again
Data in DeviceStatus table (idx 168 and 169) changed again to correct values
Everything is working correctly
My plugin has nothing to do with the idx 168 and 169 devices.
Do you know what is the reason of such situation?
Edit:
I enabled verbose logging and found that a while after enabling my plugin the problematic device were updated (float value with comma and not with dot) causing JSON parse error and prevent Device page to load
A while after disabling my plugin again, proper float value (with dot) were updated - Device page is loading correctly
Strange, isn't?
Hardware view
Hardware table
Edit:
2017-10-11 22:59:15.020 SQLR result: 168;Stacja pogodowa;1;0;0;12.4;89;3;1018;3;2017-10-11 09:29:58;;
2017-10-11 22:59:15.020 SQLQ query : UPDATE DeviceStatus SET SignalLevel=12, BatteryLevel=100, nValue=0, sValue='10,5;92;3;1018;2', LastUpdate='2017-10-11 22:59:15' WHERE (ID = 168)
2017-10-11 22:59:15.020 SQLH UpdateValueInt Stacja pogodowa HwID:9 DevID:1 Type:84 sType:1 nValue:0 sValue:10,5;92;3;1018;2
2017-10-11 22:59:15.020 SQLQ query : SELECT ID, SwitchType, LastUpdate, LastLevel, Options FROM DeviceStatus WHERE (Name == 'Stacja pogodowa')
2017-10-11 22:59:15.020 SQLR result: 168;0;2017-10-11 22:59:15;0;;
2017-10-11 22:59:15.020 RFXN : GetLightStatus Typ:84 STyp: 1 nVal:0 sVal:10,5;92;3;1018;2 llvl: 0 isDim:0 maxDim: 0 GrpCmd:0 lstat:Code: Select all
2017-10-11 23:08:53.231 SQLR result: 168;Stacja pogodowa;1;0;0;10,5;92;3;1018;2;2017-10-11 22:59:15;;
2017-10-11 23:08:53.231 SQLQ query : UPDATE DeviceStatus SET SignalLevel=12, BatteryLevel=100, nValue=0, sValue='10.5;92;3;1018;2', LastUpdate='2017-10-11 23:08:53' WHERE (ID = 168)
2017-10-11 23:08:53.231 SQLH UpdateValueInt Stacja pogodowa HwID:9 DevID:1 Type:84 sType:1 nValue:0 sValue:10.5;92;3;1018;2
2017-10-11 23:08:53.231 SQLQ query : SELECT ID, SwitchType, LastUpdate, LastLevel, Options FROM DeviceStatus WHERE (Name == 'Stacja pogodowa')
2017-10-11 23:08:53.231 SQLR result: 168;0;2017-10-11 23:08:53;0;;
2017-10-11 23:08:53.231 RFXN : GetLightStatus Typ:84 STyp: 1 nVal:0 sVal:10.5;92;3;1018;2 llvl: 0 isDim:0 maxDim: 0 GrpCmd:0 lstat:
