Beginner Troubles
Posted: Tuesday 10 October 2017 20:20
by Bernhard1
Hi, I need Help by my project. I will program a 2 point controller for a heating system.
Here my code:
if (devicechanged['Tempsensor']) then
local hysteresis = 0.2
if (otherdevices['Modus'] == 'MANUAL') then
local setpoint = otherdevices['Setpoint MANUAL']
elseif (otherdevices['Modus'] == 'AUTOMATIC') then
local setpoint = otherdevices['Setpoint AUTOMATIC']
if (otherdevices['Tempsensor'] < (setpoint - hysteresis)) then
commandArray['Output'] = 'On'
print('ON')
elseif (otherdevices['Tempsensor'] > (setpoint + hysteresis)) then
commandArray['Output'] = 'Off'
print('OFF')
by changing the Tempsensor value I got this Error:
2017-10-10 20:13:36.868 Error: EventSystem: in 001: [string "commandArray = {}..."]:13: attempt to perform arithmetic on global 'setpoint' (a nil value)
and every minute i got this one:
2017-10-10 20:14:00.489 Error: EventSystem: in 001: [string "commandArray = {}..."]:3: attempt to index global 'devicechanged' (a nil value)
Re: Beginner Troubles
Posted: Tuesday 10 October 2017 20:35
by BlueMoon
Try to declare setpoint before your if/else statement, so right after you declared hysteresis. Then give it its value within the if/else
I'm not a lua expert, but I believe the scope of the setpoint value is now only the within the if block, and another one within the else block.
Posted: Tuesday 10 October 2017 21:06
by Bernhard1
I have changed the code:
local setpoint = 0
print('ON')
print('OFF')
and the first error changed to
2017-10-10 19:47:49.311 Error: EventSystem: in 001: [string "commandArray = {}..."]:16: attempt to compare string with nil
the secound is the same
Posted: Wednesday 11 October 2017 11:53
by BlueMoon
Hmm, I looked over that one. Is your script a 'device' script? You should see it in the filename of the script.
It seems to complain about all device-related stuff, which not allowed of the script of the wrong type.
Posted: Wednesday 11 October 2017 12:02
by emme
what kind of device are setpoint MANUAL and setpoint AUTOMATIC ?
try also to declare them forcing the tonumber conversion:
setpoint = tonumber(otherdevices['Setpoint MANUAL'])
setpoint = tonumber(otherdevices['Setpoint AUTOMATIC'])
ciao
M
Posted: Wednesday 11 October 2017 21:39
by Bernhard1
Thanks a lot now it works perfekt!
I have changed the settings from "All" to "Device" which one caused
and i have added the
tonumber function several times in my code wich caused the secound error
Posted: Thursday 12 October 2017 8:46
by dannybloe
I strongly suggest that you start writing scripts using dzVents as that is much easier for beginners (an much more powerful). Check the wiki for dzVents and the forum for dzVents.
Posted: Thursday 12 October 2017 10:47
by emme
dannybloe wrote: Thursday 12 October 2017 8:46
dzVents would look something like this...
devices = {
'Tempsensor',
execute = function(dz, devTemp)
local devModus = dz.devices('Modus').value
local setPoint = 18 -- let's give at least a value to it to avoid nil errors
if devModus == 'MANUAL' then
setPoint = dz.devices('Setpoint MANUAL').setPoint
elseif devModus == 'AUTOMATIC' then
setPoint = dz.devices('Setpoint AUTOMATIC').setPoint
if devTemp.temperature < (setPoint - hysteresis) then
dz.devices('Output').switchOn().checkFirst()
dz.log('It's getting cold here... Let's heat it up for a while...',dz.LOG_FORCE)
elseif devTemp.temperature > (setPoint + hysteresis) then
dz.devices('Output').switchOff().checkFirst()
dz.log('Uh... I'm fine... Let me stop this...',dz.LOG_FORCE)
Posted: Saturday 14 October 2017 14:41
by Bernhard1
Thanks for your suggestion! dzVents is better for beginners in domoticz, Wiki for it is really great Thanks!!!
