Profile Qnect 400W On/Off switch not discovered by Domoticz
Posted: Tuesday 10 October 2017 19:19
by vangent410
I'm looking for some help in getting my Profile Qnect 400W On/Off switch to work under Domoticz.
http://www.profile.eu/en/categories/hom ... noff-400w/
I've use "Add Manual Light/Switch Device" with Device Type = ON/OFF and type = ARC, or AC, or LightwaveRF, etc... - no connection made.
( I push the button on the switch to start discovery - red led starts blinking.
Then I push "Test" button on "Add Manual Light/Switch Device" window, but never a connection is made.
I tried this out with a Klikaanklikuit switch and this worked immediately.
I'm using this Profile Qnect switch because I want to switch my light on/off under Domiticz control but at the same time, I still want to keep the manual wall-switch able to turn the light on/off.
This Qnect has dedicated 2 wires (white) to connect to the old wallswitch to perform this manual function also.
Domoticz version: Version: 3.8143
=> Can anybody give me tips or some help? What am I doing wrong? Is this Profile QNect switch at all usable with Domoticz and 433MHz?
Thanks in advance
Re: Profile Qnect 400W On/Off switch not discovered by Domoticz
Posted: Tuesday 10 October 2017 20:04
by b_weijenberg
If this is a Profile Qnect 423000040 or 423000042:
Use Ext2 firmware and enable Lighting4 and AC in the RFXtrx433E.
The Profile Qnect switch should be received as Kangtai/CoTech, this can also be tested with RFXmngr.
Posted: Tuesday 10 October 2017 23:50
by vangent410
This is a 423000062
rgds Rudi
Posted: Wednesday 11 October 2017 9:24
by b_weijenberg
Is the Profile Qnect switch received as Kangtai/CoTech in RFXmngr with Lighting4 and AC enabled?
Note: use Ext2 firmware.
Posted: Thursday 12 October 2017 0:18
by vangent410
Didn't have time today to test with RFXmgr and RFXtrx433E sender via USB to my laptop...
But I did upload a new EXT2 firmware to Domitcz for my RFXtrx433E connected to my Synology NAS, and made sure that AC and Lighting4 are enabled...
No change....still no connection when trying Add Manual Light/Switch Device via type=AC
I'll do the testing with RFXmngr in weekend
Posted: Friday 13 October 2017 18:52
by vangent410
I did the test with RFXmgr and RFXTRX433E connected to my win7 laptop:
Answer: YES...
I see the pairing LED is now on permanently on the Qnect switch.
In Rfxmgr:
OUTPUT:
Reset receiver/transceiver
Get Status
Packettype = Interface Message
subtype = Interface Response
Sequence nbr = 6
response on cmnd = Get Status
Transceiver type = 433.92MHz
Firmware version = 1021
Firmware Type = Ext2
Transmit power = 10dBm
Hardware version = 1.3
Undec off
X10 disabled
ARC enabled
AC enabled
HomeEasy EU disabled
Meiantech disabled
Oregon Scientific enabled
ATI disabled
Visonic disabled
Mertik disabled
AD enabled
Hideki disabled
La Crosse disabled
FS20/Legrand disabled
ProGuard disabled
BlindsT0 disabled
BlindsT1 disabled
AE disabled
Rubicson disabled
FineOffset disabled
Lighting4 enabled
RSL disabled
Byron SX enabled
Imagintronix disabled
KeeLoq disabled
Home Confort disabled
RFU2 disabled
RFU3 disabled
RFU4 disabled
RFU5 disabled
RFU6 enabled
RFU7 disabled
Lighting5 command
Packettype = Lighting5
subtype = Kangtai, Cotech
Sequence nbr = 7
ID = 0105 decimal:261
Unit = 11
Command = On
Signal level = 0 -120dBm
Packettype = Receiver/Transmitter Message
subtype = Transmitter Response
Sequence nbr = 7
response = ACK, data correct transmitted
Looks like the signal gets nicely seen and handled in RFXTRX433E
So, what is now the next step?
How do I get domoticz to recognize my Qnect Switch when I use ""Add Manual Light/Switch Device"?
Tips?
Posted: Friday 13 October 2017 19:24
by vangent410
Installed Domoticz version 3.8153 released (Stable)
I've found in the "release notes" for this 3.8153:
- Implemented: RFXtrx Kangtai / Cotech implemented
Tried again with "Add Manual Light/Switch Device" with Device Type = ON/OFF and type = AC... - no connection made, no switching on Qnect
Posted: Saturday 14 October 2017 10:08
by vangent410
HI,
As one can read in above thread, the QNect RECEIVER device works perfectly when we simulate a SENDER via RFXmgr and settings:
Lighting5 command
Sequence nbr = 7
Unit = 11
Command = On
How do we create a SENDER device in Domoticz to do the same as the RFXmgr?
Help please on settings in Devices tab....
--- What SWITCH TYPE to use ? ON/OFF?
--- What TYPE to use? AC? ARC? anything esle?
--- Anything else to check? in Hardware -> RTFtrx433E -> Set Mode -> there is Lighting4 and AC activated (also see above in thread)
really need some support here from somebody with experience in Domoticz................ Thanks in advance...
Posted: Monday 16 October 2017 21:23
by vangent410
Anybody able to help out here?
I bought a Qnect remote control SENDER (able to switch 4 receivers) and use LEarn Light/Switch to discover when I push "A"=on.
It was discover as a Type="blind".
Now using this new device in domoticz is not triggering the RECEIVE Qnect switch.
Using the remote SENDER control is triggering ON or OFF.
So.....
HELP please...somebody who knows Domoticz protocols
