variables lastUpdate mismatch?
Posted: Monday 02 October 2017 22:08
by emme
Ciao,
I'm getting a wired behaivour on calculating the varibale lastupdate...
in my script I have:
if domoticz.variables('PRESENTE').lastUpdate.minutesAgo > 10 then
domoticz.log('Variabile '..domoticz.variables('PRESENTE').value..' Update '..domoticz.variables('PRESENTE').lastUpdate.minutesAgo,domoticz.LOG_FORCE)
but the result is not in minutes and I cannot even understand the measure (though they were secs, but they are not)
the log:
2017-10-02 22:05:00.129 dzVents: !Info: Variabile 1 Update 767
2017-10-02 22:06:00.202 dzVents: !Info: Variabile 1 Update 768
the user variable panel shows...
34 PRESENTE Stringa 1 2017-10-02 21:52:10
the lastupdate should return 8.... not 767 neither 768...
am I wrong?
Re: variables lastUpdate mismatch?
Posted: Tuesday 03 October 2017 8:20
by dannybloe
That's weird. Could you enable debug logging (Domoticz settings) and run your script. Then, in /path/to/domoticz/scripts/dzVents open domoticzData.lua and find the section for your variable and paste it here? (Don't forget to disable debug logging afterwards).
Posted: Tuesday 03 October 2017 9:55
by emme
ciao,
thanks
here is the section:
[172] = {
["name"] = "PRESENTE";
["baseType"] = "uservariable";
["changed"] = false;
["id"] = 34;
["variableType"] = "string";
["data"] = {
["value"] = "2";
["lastUpdate"] = "2017-10-02 09:17:36";
while the real lastupdate is 2017-10-03 07:31:11
thanks
ciao
M
Posted: Friday 06 October 2017 10:17
by emme
after updating to 8551 ad upgraded dzvents to 2.30... still got the same issue... variables are not responding correctly to the .lastUpdate.minutesAgo function... providing the difference when the variable was firstly discovered
What could I check more to fix this?
thanks
ciao
M
Posted: Friday 06 October 2017 10:24
by dannybloe
Can you describe in steps what it is exactly what you do and in what order and what you got and what you expected?
Posted: Friday 06 October 2017 10:39
by emme
ciao,
let's recap all the stuff....
I have a uservariable updated by a dzVents script, the variable is called PRESENTE (actually it counts the BLE devices discovered in the house)
I have a timer script that evaluates it:
if its values is setted to 0 more than 10 minutes ago then switch off lights
I would not use the .switchOff.afterMins(10) beacuse the command cannot be cancelled
the variable is updated by anothe device dzvents script that calculates it.
so... in a typical scenario I could have the variable at its state:
- Variabile PRESENTE
- varPRESENTE.jpg (3.93 KiB) Viewed 3042 times
(as you see the lastupdate is 2017-10-06 10:13:53... more or less 26 minutes ago)
I created a simple dzVents script to dump the value:
variables = {
'NUT_*'
execute = function(dz, var)
dz.log('Variable '..var.name..' was changed since '..var.lastUpdate.minutesAgo , dz.LOG_FORCE)
dz.log('Variable PRESENTE'..' was changed since '..dz.variables('PRESENTE').lastUpdate.minutesAgo , dz.LOG_FORCE)
(the trigger is another variable just to compare)
the log show
2017-10-06 10:36:33.265 dzVents: !Info: Variable NUT_Marco was changed since 30
2017-10-06 10:36:33.265 dzVents: !Info: Variable PRESENT E was changed since 168
...well... both variables are wrongly calculated... NUT_Marco should be 0 (it was the trigger), and PRESENTE would be 26...
thanks for your patience
ciao
M
Posted: Friday 06 October 2017 10:48
by dannybloe
Ah, well, no.. it is different from what you expect..
If you have a trigger for a device or variable then lastUpdate is the timestamp of the PREVIOUS update in the database. Not the current one as the current one is always the current time and lastUpdate.minAgo() would always be 0. That is done deliberately so you can check how long it has been between the current update (now) and the previous one.
However, if you have a timer script and it checks the lastUpdate of a device (or variable) then its lastUpdate is the time it was last updated in the database.
So, there's a clear difference there.
Posted: Friday 06 October 2017 11:00
by emme
ah ok... it make sense for the device trigger part... I'm fine with that... (thanks for clarify
but not for the other (the PRESENTE Variable)...
I just make a change to the test script in order to dump a bit more information about it:
the print line has changed to:
dz.log('Variable PRESENTE '..dz.variables('PRESENTE').lastUpdate.raw..' was changed since '..dz.variables('PRESENTE').lastUpdate.minutesAgo , dz.LOG_FORCE)
the result is:
2017-10-06 10:52:12.259 dzVents: !Info: Variable PRESENTE 2017-10-06 07:47:57 was changed since 184
whitch is not real...
by my understanding (just made a try and I can confirm you) the value update only if I reboot domoticz (or restart the service) and does not affect devices... just variables....
Posted: Friday 06 October 2017 11:18
by dannybloe
Weird.. I cannot reproduce this. This what I did:
I created a dummy switch and a variable.
I created a trigger script for the switch which sets the variable to a value
I created a trigger script for the variable printing lastUpdate.secondsAgo
I created a timer script that prints variable lastUpdate.secondsAgo every minute.
All logs show the correct time for secondsAgo and lastUpdate is accurate whenever I press the switch.
Or should I do something else to reproduce this?
Posted: Friday 06 October 2017 11:20
by emme
try it back in one hour and check if the minutesAgo for the variable is still correct
small update....
Looks like is not a dzVents issue:
print('PRESENTE'..uservariables_lastupdate['PRESENTE'])
returns the same incorrect timeStamp
Posted: Friday 06 October 2017 12:57
by dannybloe
I still cannot reproduce this. Even after an hour the timestamps are still correct. Can you create a test similar to what I did above?
Posted: Friday 06 October 2017 13:07
by jake
It must be something in domoticz itself. I have a normal Lua script that send a notification when a light is on more than 5 minutes. I haven't changed that script for ages, but since a couple of weeks the notification is sent at the same time as when I turn on that light.
I therefore also think that somehow the time calculation is wrong in general nowadays.
To play with it, I turned the light on and off a couple of times. Out of 4 trials, it somehow behaved correctly 1 time.
Verstuurd vanaf mijn SM-G930F met Tapatalk
Posted: Friday 06 October 2017 13:10
by dannybloe
I actually don't care what is causing it right now. I want something to reproduce this behaviour so we can fix it (wherever it is).
Posted: Friday 06 October 2017 13:19
by jvandenbroek
Posted: Monday 09 October 2017 8:54
by emme
I've seen in 3.8562 this has benn addressed and fixed!
thank you guys!!!
