oregon wgr800 wind sensor with wrong temperature gauge
gonzzo
Post by gonzzo »
I've installed through RFLink an Oregon WGR800 device and all works fine but that it shows the temperature measure which is something the device deos not provide (not reflected in the device output into RFLink) but Domoticz is showing a temperature measure always with the same value: -2.1ºC
I've looked at the specs of the WGR800 and I don't see any temperature sensor so I guess this is comming from a wrong configuration in Domotizc but I'm not able to eliminate.
The device is taged as "Veleta Terrada" and as seen in the picture it includes two sensors, wind and temperature where ti should have only the wind sensor.
Is there any way I can remove this sensor in the configuration files? If I go to devices, it only shows the wind sensor so I can't remove the temperature one.
Thanks,
Mazzokun
Re: oregon wgr800 wind sensor with wrong temperature gauge
Post by Mazzokun »
Same bug here!
Anyone has a solution?
