conditional timer trigger
Posted: Saturday 30 September 2017 10:22
by dlefol
I have a script in dzVents turning every 2 minutes using a timer trigger. In that script, the first thing I do is check if a specific value is ON and if it is the case I peform some actions. The script looks like this:
    active = true,
                timer = {
                                'Every 2 minutes'
    execute = function(domoticz)
        if(domoticz.devices(automation).state == 'On') then
             -- Perform some actions and checks every 2 minutes
I was wondering if it would be possible to optimise this by triggering the timer call every 2 minutes only when the switch is ON, something looking a bit like that basically:
    active = true,
                timer = {
                                'Every 2 minutes' if domoticz.devices(automation).state == 'On'
I tried to look around but could not see anything looking like this. Any ideas ?
Cheers
Re: conditional timer trigger
Posted: Wednesday 04 October 2017 9:19
by BakSeeDaa
dlefol wrote: Saturday 30 September 2017 10:22 ... Any ideas ?
Cheers
According to the documentation you can use a function in the timer table...
        function(domoticz)
            -- you can use domoticz.time to get the current time
            -- note that this function is called every minute!
            -- custom code that either returns true or false
But it won't speed up your script. In fact it would slow things down because your function will be evaluated every minute.
Even if your statement
would work, it would still have to be evaluated every minute, hence wouldn't optimize your script in a positive direction.
Posted: Wednesday 04 October 2017 10:15
by dlefol
good point I didn't think about that.
Thanks for taking the time to reply :)
Posted: Wednesday 04 October 2017 11:01
by dannybloe
I would do it in your execute block in this case as the execute-block is only executed when the triggers (device and timers) are met while a timer function is evaluated for EVERY event that is triggered in Domoticz. So for performance reasons put as much logic that uses device information in the execute block.
