Configure Z-wave device
Posted: Friday 29 September 2017 7:29
I've a problem with a battery powered z-wave Multi sensor containing a movement, humidity, light (lux),.. sensors.
As the device is battery powered the device will become aware every 2 hours.
The movement sensor is working fine, from the moment movement is detected the sensor reports the status. For the humidity sensor the report should be sent when there is a step noticed of 1%. Problem now is that the sensor is not sending humidity reports.
What I want to do is that once movement is detected I want to modify the device configuration in that way that the sensor reports every 30 sec for example the humidity instead of using the threshold.
Question: can this be done via LUA script (JSON)?
Can someone give some advice, code examples?
Thanks a lot
Thanks a lot
