Cannot Use Domoticz.image from plugin to update sensor image
Posted: Thursday 28 September 2017 11:57
by ycahome
i have created one thread on "Bugs and Threads" but i don't realy know if its a problems or its "by design".
http://www.domoticz.com/forum/viewtopic.php?f=6&t=19534
So, my question is: Can i use "Domoticz.Image(icon)" and "Devices[1].Update(0, str(1), Image=Images[icon].ID)" to continuously change the icon of a virtual sensor (for example an Alert Sensor)?
What am trying to achieve here is to create a plugin that will have the moon phases and icon will show the current phase.
Any help will be appreciated,
Re: Use Domoticz.image from plugin to update sensor image
Posted: Thursday 28 September 2017 12:30
by zak45
Should be possible, but I think that your sensor device need to be created by the plugin itself.
see
http://www.domoticz.com/wiki/Plugins/BatteryLevel.html
Posted: Thursday 28 September 2017 13:20
by ycahome
then, something is going wrong with me.
Tested in 2 different domoticz systems (Ubuntu Version: 3.8153 and raspberry Version: 3.8153)
----possible problem in that version???????
Seems that everything in the code is written as expected, check bellow (and icons are attached):
Can you test it and tell me what is the behavior to your installation?
<plugin key="MoonPhases" name="Moon Phases" author=" " version="1.0.0" wikilink="http://www.domoticz.com/wiki/plugins/" externallink=" ">
<params>
<param field="Mode1" label="Key WU" width="200px" required="true" default=""/>
<param field="Mode2" label="Code Country" width="100px" required="true" default="fr"/>
<param field="Mode3" label="City" width="300px" required="true" default="paris"/>
<param field="Mode4" label="Polling interval (minutes, 30 mini)" width="40px" required="true" default="2"/>
<param field="Mode6" label="Debug" width="75px">
<options>
<option label="True" value="Debug"/>
<option label="False" value="Normal" default="True" />
</options>
</param>
</params>
</plugin>
import Domoticz
# import urllib
# from urllib.request import request, urlopen
import urllib.request
import json
from datetime import datetime
from datetime import timedelta
icons = {"NewMoon": "NewMoon.zip",
"WaxingCrescent": "WaxingCrescent.zip",
"FirstQuarter": "FirstQuarter.zip",
"WaxingGibbous": "WaxingGibbous.zip",
"Full": "Full.zip",
"WaningGibbous": "WaningGibbous.zip",
"LastQuarter": "LastQuarter.zip",
"WaningCrescent": "WaningCrescent.zip"}
class BasePlugin:
def __init__(self):
self.debug = False
self.nextupdate = datetime.now()
self.pollinterval = 60 # default polling interval in minutes
self.error = False
return
def onStart(self):
global icons
Domoticz.Debug("onStart called")
if Parameters["Mode6"] == 'Debug':
self.debug = True
Domoticz.Debugging(1)
DumpConfigToLog()
else:
Domoticz.Debugging(0)
# load custom MoonPhase images
for key, value in icons.items():
if key not in Images:
Domoticz.Image(value).Create()
Domoticz.Debug("Added icon: " + key + " from file " + value)
Domoticz.Debug("Number of icons loaded = " + str(len(Images)))
for image in Images:
Domoticz.Debug("Icon " + str(Images[image].ID) + " " + Images[image].Name)
# create the mandatory child device if it does not yet exist
if 1 not in Devices:
Domoticz.Device(Name="Lune", Unit=1, TypeName="Custom",Options={"Custom": "1;"},Used=1).Create()
# check polling interval parameter
try:
temp = int(Parameters["Mode4"])
except:
Domoticz.Error("Invalid polling interval parameter")
else:
if temp < 1:
temp = 1 # minimum polling interval
Domoticz.Error("Specified polling interval too short: changed to 30 minutes")
elif temp > 1440:
temp = 1440 # maximum polling interval is 1 day
Domoticz.Error("Specified polling interval too long: changed to 1440 minutes (24 hours)")
self.pollinterval = temp
Domoticz.Log("Using polling interval of {} minutes".format(str(self.pollinterval)))
def onStop(self):
Domoticz.Debug("onStop called")
def onHeartbeat(self):
now = datetime.now()
if now >= self.nextupdate:
self.nextupdate = now + timedelta(minutes=self.pollinterval)
# data=json.loads(urllib.request.urlopen("http://api.wunderground.com/api/5ea448da70b1136f/astronomy/q/fr/paris.json").read().decode('ascii'))
data = json.loads(urllib.request.urlopen(
"http://api.wunderground.com/api/" + Parameters["Mode1"] + "/astronomy/q/" + Parameters["Mode2"] + "/" +
Parameters["Mode3"] + ".json").read().decode('ascii'))
lune = data['moon_phase']['phaseofMoon']
# Domoticz.Log(str(lune))
Domoticz.Log("Lune Data:"+str(lune))
self.UpdateDevice(lune)
def UpdateDevice(self, lune):
# Make sure that the Domoticz device still exists (they can be deleted) before updating it
if 1 in Devices:
if lune == "New Moon":
icon = "NewMoon"
datafr = "New Moon"
elif lune == "Waxing Crescent":
icon = "WaxingCrescent"
datafr = "Waxing Crescent"
elif lune == "First Quarter":
icon = "FirstQuarter"
datafr = "First Quarter"
elif lune == "Waxing Gibbous":
icon = "WaxingGibbous"
datafr = "Waxing Gibbous"
elif lune == "Full":
icon = "Full"
datafr = "Full"
elif lune == "Waning Gibbous":
icon = "WaningGibbous"
datafr = "Waning Gibbous"
elif lune == "Last Quarter":
icon = "LastQuarter"
datafr = "Last Quarter"
elif lune == "WaningCrescent":
icon = "WaningCrescent"
datafr = "WaningCrescent"
#Domoticz.Debug("Icon " + str(Images[icon].ID))
Devices[1].Update(0, str(lune), Image=Images[icon].ID)
return
global _plugin
_plugin = BasePlugin()
def onStart():
global _plugin
_plugin.onStart()
def onStop():
global _plugin
_plugin.onStop()
def onHeartbeat():
global _plugin
_plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
for x in Parameters:
if Parameters[x] != "":
Domoticz.Debug("'" + x + "':'" + str(Parameters[x]) + "'")
Domoticz.Debug("Device count: " + str(len(Devices)))
for x in Devices:
Domoticz.Debug("Device: " + str(x) + " - " + str(Devices[x]))
Domoticz.Debug("Device ID: '" + str(Devices[x].ID) + "'")
Domoticz.Debug("Device Name: '" + Devices[x].Name + "'")
Domoticz.Debug("Device nValue: " + str(Devices[x].nValue))
Domoticz.Debug("Device sValue: '" + Devices[x].sValue + "'")
return
The symptom is: The first time that domoticz creates those icons everything goes well. On restart, or plugin update, adds only one image to the array. But icons are available via domoticz console
2017-09-28 14:25:28.603 (MoonPhases) Creating images from file '/home/pi/domoticz/plugins/MoonPhases/WaningGibbous.zip'.
2017-09-28 14:25:28.616 (MoonPhases) Added icon: WaningGibbous from file WaningGibbous.zip
2017-09-28 14:25:28.616 (MoonPhases) Creating images from file '/home/pi/domoticz/plugins/MoonPhases/WaxingCrescent.zip'.
2017-09-28 14:25:28.627 (MoonPhases) Added icon: WaxingCrescent from file WaxingCrescent.zip
2017-09-28 14:25:28.627 (MoonPhases) Creating images from file '/home/pi/domoticz/plugins/MoonPhases/FirstQuarter.zip'.
2017-09-28 14:25:28.638 (MoonPhases) Added icon: FirstQuarter from file FirstQuarter.zip
2017-09-28 14:25:28.638 (MoonPhases) Creating images from file '/home/pi/domoticz/plugins/MoonPhases/WaningCrescent.zip'.
2017-09-28 14:25:28.650 (MoonPhases) Added icon: WaningCrescent from file WaningCrescent.zip
2017-09-28 14:25:28.650 (MoonPhases) Creating images from file '/home/pi/domoticz/plugins/MoonPhases/WaxingGibbous.zip'.
2017-09-28 14:25:28.662 (MoonPhases) Added icon: WaxingGibbous from file WaxingGibbous.zip
2017-09-28 14:25:28.662 (MoonPhases) Creating images from file '/home/pi/domoticz/plugins/MoonPhases/LastQuarter.zip'.
2017-09-28 14:25:28.673 (MoonPhases) Added icon: LastQuarter from file LastQuarter.zip
2017-09-28 14:25:28.674 (MoonPhases) Creating images from file '/home/pi/domoticz/plugins/MoonPhases/Full.zip'.
2017-09-28 14:25:28.685 (MoonPhases) Added icon: Full from file Full.zip
2017-09-28 14:25:28.685 (MoonPhases) Number of icons loaded = 1
2017-09-28 14:25:28.685 (MoonPhases) Icon 108 NewMoon
Posted: Thursday 28 September 2017 17:35
by zak45
looks like the same, but don't know if this is normal or not ?? !!!
2017-09-28 17:32:28.168 (zz) Initialized version 1.0.0, author ' '
2017-09-28 17:32:28.168 (zz) Entering work loop.
2017-09-28 17:32:28.168 (zz) Debug log level set to: 'true'.
2017-09-28 17:32:28.168 (zz) 'Name':'zz'
2017-09-28 17:32:28.168 (zz) 'HardwareID':'19'
2017-09-28 17:32:28.168 (zz) 'Mode6':'Debug'
2017-09-28 17:32:28.168 (zz) 'Mode2':'fr'
2017-09-28 17:32:28.168 (zz) 'Port':'0'
2017-09-28 17:32:28.168 (zz) 'HomeFolder':'C:\Program Files (x86)\Domoticz\plugins\MoonPhases\'
2017-09-28 17:32:28.168 (zz) 'Key':'MoonPhases'
2017-09-28 17:32:28.168 (zz) 'Mode4':'2'
2017-09-28 17:32:28.168 (zz) 'Version':'1.0.0'
2017-09-28 17:32:28.168 (zz) 'Mode1':'5ea448da70b1136f'
2017-09-28 17:32:28.168 (zz) 'Mode3':'paris'
2017-09-28 17:32:28.168 (zz) 'Author':' '
2017-09-28 17:32:28.168 (zz) Device count: 1
2017-09-28 17:32:28.168 (zz) Device: 1 - ID: 937, Name: 'zz - Lune', nValue: 0, sValue: 'First Quarter'
2017-09-28 17:32:28.168 (zz) Device ID: '937'
2017-09-28 17:32:28.168 (zz) Device Name: 'zz - Lune'
2017-09-28 17:32:28.168 (zz) Device nValue: 0
2017-09-28 17:32:28.168 (zz) Device sValue: 'First Quarter'
2017-09-28 17:32:28.168 (zz) Creating images from file 'C:\Program Files (x86)\Domoticz\plugins\MoonPhases\WaningGibbous.zip'.
2017-09-28 17:32:28.215 (zz) Added icon: WaningGibbous from file WaningGibbous.zip
2017-09-28 17:32:28.215 (zz) Creating images from file 'C:\Program Files (x86)\Domoticz\plugins\MoonPhases\FirstQuarter.zip'.
2017-09-28 17:32:28.278 (zz) Added icon: FirstQuarter from file FirstQuarter.zip
2017-09-28 17:32:28.278 (zz) Creating images from file 'C:\Program Files (x86)\Domoticz\plugins\MoonPhases\NewMoon.zip'.
2017-09-28 17:32:28.324 (zz) Added icon: NewMoon from file NewMoon.zip
2017-09-28 17:32:28.324 (zz) Creating images from file 'C:\Program Files (x86)\Domoticz\plugins\MoonPhases\LastQuarter.zip'.
2017-09-28 17:32:28.387 (zz) Added icon: LastQuarter from file LastQuarter.zip
2017-09-28 17:32:28.387 (zz) Creating images from file 'C:\Program Files (x86)\Domoticz\plugins\MoonPhases\WaxingGibbous.zip'.
2017-09-28 17:32:28.449 (zz) Added icon: WaxingGibbous from file WaxingGibbous.zip
2017-09-28 17:32:28.449 (zz) Creating images from file 'C:\Program Files (x86)\Domoticz\plugins\MoonPhases\WaxingCrescent.zip'.
2017-09-28 17:32:28.512 (zz) Added icon: WaxingCrescent from file WaxingCrescent.zip
2017-09-28 17:32:28.512 (zz) Creating images from file 'C:\Program Files (x86)\Domoticz\plugins\MoonPhases\WaningCrescent.zip'.
2017-09-28 17:32:28.559 (zz) Added icon: WaningCrescent from file WaningCrescent.zip
2017-09-28 17:32:28.559 (zz) Number of icons loaded = 1
2017-09-28 17:32:28.559 (zz) Icon 115 Full
2017-09-28 17:32:28.559 (zz) Using polling interval of 2 minutes
2017-09-28 17:32:37.762 (zz) Calling message handler 'onHeartbeat'.
2017-09-28 17:32:38.044 (zz) Lune Data:First Quarter
2017-09-28 17:32:38.044 Error: (zz) 'onHeartbeat' failed 'KeyError'.
2017-09-28 17:32:38.059 Error: (zz) ----> Line 152 in C:\Program Files (x86)\Domoticz\plugins\MoonPhases\plugin.py, function onHeartbeat
2017-09-28 17:32:38.059 Error: (zz) ----> Line 101 in C:\Program Files (x86)\Domoticz\plugins\MoonPhases\plugin.py, function onHeartbeat
2017-09-28 17:32:38.059 Error: (zz) ----> Line 135 in C:\Program Files (x86)\Domoticz\plugins\MoonPhases\plugin.py, function UpdateDevice
2017-09-28 17:32:47.935 (zz) Calling message handler 'onHeartbeat'.
2017-09-28 17:32:49.310 (RFX433E) Energy (Compteur EDF)
Posted: Monday 02 October 2017 10:43
by ycahome
Can someone from the dev team of the python framework answer this ?
Is it a problem to our installations or a bug?
Also, tried to contact the developer of the z-wave Battery plugin (Logread) but seems that his mailbox is full.
Posted: Monday 02 October 2017 19:31
by Logread
ycahome wrote: ↑Monday 02 October 2017 10:43
I got your pm
Pretty tied up right now but I’ll look into what you posted earlier in the thread as soon as possible... Icons files can be very tricky to get to work (espcially the plugin key must match in all the icons.txt files. Bear with me please
Posted: Monday 02 October 2017 22:32
by ycahome
Logread wrote: ↑Monday 02 October 2017 19:31
Bear with me please
Nice.
In the meantime I have tried with different sets of ready made icons (from domoticz repository) without success.
Even tried with your plugin modified.
Domoticz.image seems poorly documented.
Especially for the "icons.txt" file, the wiki pages have conflicting articles. Sometimes documentation say "name;plugin name;description" while others "name;name;description".
My latest finding is that image array keeps only the last image created, all previously added images were removed. (Although all images were actually added to domoticz console).
Re: Cannot Use Domoticz.image from plugin to update sensor image
Posted: Tuesday 03 October 2017 3:36
by Dnpwwo
@ycahome,
The plugin doc (
http://www.domoticz.com/wiki/Developing ... gin#Images) tries to show that the framework maps the images to the plugin using the plugin's unique key. Because the Python framework is on top of existing Domoticz somethings are not as perfect as they might be if designed from scratch and this is an example.
If your plugin key is "MoonPhases" then icons.txt needs to refer to that so that Domoticz knows which images to load.
Rather than:
WaningGibbous;WaningGibbous;WaningGibbous MoonPhases
try:
MoonPhasesWaningGibbous;WaningGibbous;WaningGibbous MoonPhases
or:
MoonPhasesWG;WaningGibbous;WaningGibbous MoonPhases
and the Images will show up in the Images dict and the image number will be available.
The Device.Update will set the LastSeen on the device as well so the Domoticz front end should refresh as long as th type of device supports custom images.
Posted: Tuesday 03 October 2017 10:06
by ycahome
Dnpwwo wrote: ↑Tuesday 03 October 2017 3:36
@ycahome,
The plugin doc (
Rather than:
try:
or:
MANY THANKS dnpwwo for this clarification.
Solution was too simple for the effort given by myself.
Thought that where just examples and that there is no relation between "icons.txt" contents and the plugin key
(which is obvious wrong assumption)
Maybe its a good opportunity to make a distinct Wiki note:
NOTE:"icons.txt" file contents should be prefixed with your plugin key
example:
if your plugin key is "myPlugin" your "icons.txt" file may look like :
myPluginIcon1;Icon1Name;Plugin Description
