kaku ALED-2709
Posted: Tuesday 26 September 2017 21:45
by Eddiever
A nice neighbour of mine gave me a kaku ALED-2709 led light (dimmable).
https://www.gamma.nl/assortiment/klikaa ... /p/B549083 Dutch. How do I connect this device to Domoticz? Through Devices it didn't show up unfortunately.
Re: kaku ALED-2709
Posted: Tuesday 26 September 2017 21:51
by manjh
The Gamma description says that this lamp can be controlled via the normal KAKU remote control units. I would expect that you can link it using the normal KAKU method:
1. go to the switches page and then click manually add a switch.
2. select either ARC or AC for an RF controlled switch, select an address (doesn't matter which)
3. put the lamp in "learn" mode. If you don't know how, look it up on the KlikAanKlikUit site
https://www.klikaanklikuit.nl/nl/produc ... mbaar.html
Look under "downloads
4. immediately then press the test button on the Domoticz screen.
5. The light should now be coupled to the address you specified. The lamp will confirm this by blinking twice.
Re: kaku ALED-2709
Posted: Tuesday 26 September 2017 21:54
by manjh
(msg removed)
Re: kaku ALED-2709
Posted: Tuesday 26 September 2017 22:12
by Eddiever
manjh, thanks for the quick reply. This did the trick. Again: thank you!
