Weather Underground failover suggestion
rolandbreedveld
Domoticz version: 2021.1
Post by rolandbreedveld »
Because the weather underground stations in my neighbourhood, sometimes are of duty for some hours to days,
I want to suggest to add a secondary and perhaps a third station ID in case the primary station fails for e.g. more than 1 hour.
A the moment I solve this with a Unix (cron) script which changes the weather-station-id if it's of-line for longer than 1 hour directly in the database.
Raspberry Pi(SSD)+UPS HAT,Dashticz on WallTablet,HomeBridge, P1, HarmonyHub,FritzBox,API to 123Solar+ABB-PowerOne+SMA,ESP-Leds(flashed LSC),Tasmota,Shelly,MQTT,Mosquito,Node-Red,http://wiki.breedveld.net/index.php?title=RPiWaterMeter, Mercedes-Me
rolandbreedveld
Re: Weather Underground failover suggestion
For those who are interested:
#!/bin/bash
# check_weater_stations.sh
# 2017-09-27 V1.0 Roland Breedveld
IDX=10
HID=5
PRI="pws:IXXXX201"
SEC="pws:IXXXX97"
API_KEY="xxxxxxxx"
DATE=$(date -d '1 hour ago' '+%Y-%m-%d %H:%M:00')
CUR=$(sqlite3 /home/pi/domoticz/domoticz.db "select Password from hardware where id = '${HID}' ;")
ACTIVE=$(sqlite3 /home/pi/domoticz/domoticz.db "select * from temperature where devicerowid = '${IDX}' and date >= '${DATE}' ;")
if [ "${CUR}" == "${PRI}" ]
then
if [ ! -z "${ACTIVE}" ]
then
echo "Primair Station ${PRI} active"
echo "Primair Station ${PRI} no data"
echo "Failover to Secundair Station ${SEC}"
sqlite3 /home/pi/domoticz/domoticz.db "update hardware set Password='${SEC}' where id = '${HID}' ;"
fi
WDATE=$(wget -O - http://api.wunderground.com/api/${API_K ... {PRI}.json 2>&1|grep "observation_time_rfc822"| awk -F\" '{print $4}')
echo ${WDATE}
ZDATE=$(date -d"${WDATE}" +%s)
ZNOW=$(date +%s)
ZDIFF=$(echo "0$ZNOW 0$ZDATE"|awk '{print ( $1 - $2 )}')
if [ "${ZDIFF}" -gt "1800" ]
then
echo "Primair Station ${PRI} to old: keep Secundary Station ${SEC}"
if [ -z "${ACTIVE}" ]
then
echo "Both Stations are Offline"
fi
echo "Go back to Primary Station ${PRI}"
sqlite3 /home/pi/domoticz/domoticz.db "update hardware set Password='${PRI}' where id = '${HID}' ;"
fi
fi
jake
Post by jake »
Thanks for this script. Do you simply call it every hour?
It would be nicer indeed to have this kind of functionality integrated on the Domoticz hardware page for this 'hardware'
gajotnt
Domoticz version: V4.9700
Post by gajotnt »
Would be really awesome to include in hardware page
