Somfy Telis 4 RTS - Favorite position
Kennet
Domoticz version: 3.8153
Post by Kennet »
I have a Synology NAS working with the RFLink (R47).
I am am controlling Somfy blinds (1002295A Tilt&Lift 25 RTS Central)
I have setup the RFLink as a new control point in addition to a Telis 4 controller.
This is working fine for controlling UP and DOWN and STOP (MY) when the blinds are in motion.
However the STOP/MY button also works as a go to "Favorite position" on the Telis remote.
When the blinds are not in motion and I activate the button the blinds go to a preprogrammed position.
But this function is not working when I do it from the RFLink. I have mostly used the RFLinkLoader.exe to test but it is the same when I activate it from the NAS.
Can anybody help me understand how the STOP button can work fine when the blinds are in motion but not when the blinds are stopped.
I am assuming that it is the exact same command that will be send.
I have see it working a single time out of I guess 50 times I have tried it.
I have moved the RFLink to within a few meters of the blinds.
Below I have added debug log of when I activate STOP/MY on the Telis
20;11;DEBUG;Pulses=82;Pulses(uSec)=2370,2430,2370,2430,4680,1200,1170,1200,1170,1200,540,540,1170,1200,540,540,1170,1200,540,540,1170,570,540,540,540,540,540,1200,1170,1200,540,540,1170,570,540,1200,1170,1200,1170,1200,540,540,1170,1200,540,570,1170,1200,1170,540,540,540,540,540,540,570,540,1200,540,540,1170,570,540,540,540,1200,1170,570,540,570,540,1200,1170,1200,1170,1200,1170,1200,1170,1200,510,6990;
20;12;Debug;RTS P1;ad1d0204359244;
20;13;RTS;ID=359244;SWITCH=01;CMD=STOP;
20;14;DEBUG;Pulses=84;Pulses(uSec)=2370,2430,2370,2430,4680,1170,1170,1200,1170,1200,540,540,540,540,1170,1200,1170,1200,540,540,1170,540,540,540,540,1200,540,570,1170,1200,540,540,1170,540,540,1200,540,570,540,540,1170,1200,540,570,1170,1200,540,540,1170,1200,1170,540,540,540,540,540,540,540,540,1200,540,570,1170,540,540,540,540,1200,1170,540,540,540,540,1200,1170,1200,1170,1200,1170,1200,1170,1200,510,6990;
20;15;Debug;RTS P1;ae1f0205359244;
20;16;RTS;ID=359244;SWITCH=01;CMD=STOP;
20;17;DEBUG;Pulses=94;Pulses(uSec)=2460,2430,2370,2430,2370,2430,2370,2430,2370,2430,2370,2430,2370,2430,4680,1200,1170,1200,1170,1200,540,540,540,540,1170,1200,1170,1200,540,540,1170,540,540,540,540,1200,540,540,1170,1200,540,540,1170,540,540,1200,540,540,540,540,1170,1170,540,540,1170,1200,540,540,1170,1200,1170,540,540,540,540,540,540,540,540,1200,540,540,1170,540,540,540,540,1200,1170,540,540,540,540,1200,1170,1200,1170,1200,1170,1200,1170,1200,510,6990;
20;18;Debug;RTS P1;ae1f0205359244;
20;19;RTS;ID=359244;SWITCH=01;CMD=STOP;
20;1A;DEBUG;Pulses=96;Pulses(uSec)=2400,2430,2370,2400,4710,1170,1170,1200,1170,1200,540,540,540,540,540,540,540,540,540,540,540,540,1170,540,540,1170,540,540,540,540,540,540,540,540,540,540,1170,540,540,1170,1170,1200,540,540,540,540,540,540,1170,540,540,540,540,1200,540,540,540,570,540,540,1170,1200,1170,1200,540,540,1170,540,540,1170,1170,540,540,540,540,1170,1170,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,6990;
20;1B;Debug;RTS P1;af480206359244;
20;1C;RTS;ID=359244;SWITCH=01;CMD=DOWN;
20;1D;DEBUG;Pulses=94;Pulses(uSec)=2370,2430,2370,2430,4680,1170,1170,1200,1170,540,540,540,540,540,540,540,540,1200,540,540,540,540,1170,540,540,1200,540,540,1170,1170,540,540,540,540,1170,540,540,1200,1170,540,540,1170,540,540,540,540,1170,540,540,540,540,1200,540,540,540,540,540,540,1170,1200,1170,1170,540,540,1170,540,540,1170,1170,540,540,540,540,1170,1170,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,6990;
20;1E;Debug;RTS P1;a0460207359244;
20;1F;RTS;ID=359244;SWITCH=01;CMD=DOWN;
20;20;DEBUG;Pulses=104;Pulses(uSec)=2460,2430,2370,2430,2370,2430,2370,2430,2370,2430,2370,2430,2370,2430,4680,1170,1170,1200,1170,540,540,540,540,540,540,540,540,1200,540,540,540,540,1170,540,540,1200,540,570,1170,1200,540,540,540,570,1170,540,540,1200,1170,540,540,1200,540,540,540,540,1170,540,540,540,540,1200,540,540,540,540,540,540,1170,1200,1170,1200,540,540,1170,540,540,1200,1170,540,540,540,540,1200,1170,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,540,6990;
20;21;Debug;RTS P1;a0460207359244;
20;22;RTS;ID=359244;SWITCH=01;CMD=DOWN;
20;23;DEBUG;Pulses=86;Pulses(uSec)=2370,2430,2370,2430,4680,1200,1170,1200,1170,540,540,540,540,540,540,1170,540,540,1170,1200,540,540,540,540,540,540,1170,540,540,1200,1170,1200,540,540,540,540,540,540,540,570,1170,1200,1170,1200,540,540,1170,1200,540,540,1170,1170,1170,540,540,540,540,540,540,540,540,1200,540,540,1170,540,540,540,540,1200,1170,540,540,540,540,1200,1170,1200,1170,1200,1170,1200,1170,1200,510,6990;
20;24;Debug;RTS P1;a11d0208359244;
20;25;RTS;ID=359244;SWITCH=01;CMD=STOP;
20;26;DEBUG;Pulses=86;Pulses(uSec)=2370,2430,2370,2430,4680,1200,1170,1170,1170,540,540,540,540,1170,1170,1200,1170,1170,540,540,540,540,540,540,1170,1200,540,570,1170,1170,540,540,540,540,540,540,540,540,540,540,540,540,1170,1200,540,540,1170,1200,540,540,1170,1200,1170,540,540,540,540,540,540,540,540,1170,540,540,1170,540,540,540,540,1200,1170,540,540,540,540,1200,1170,1200,1170,1200,1170,1200,1170,1200,510,6990;
20;27;Debug;RTS P1;a21f0209359244;
20;28;RTS;ID=359244;SWITCH=01;CMD=STOP;
20;29;DEBUG;Pulses=96;Pulses(uSec)=2460,2430,2370,2430,2370,2430,2370,2430,2370,2430,2370,2430,2370,2430,4680,1200,1170,1200,1170,540,540,540,540,1200,1170,1200,1170,1200,540,540,540,540,540,540,1170,1200,540,540,1170,1200,540,540,540,540,540,540,540,540,540,540,540,540,1170,1200,540,540,1170,1200,540,540,1170,1200,1170,540,540,540,540,570,540,540,540,1200,540,540,1170,540,540,540,540,1170,1170,540,540,540,540,1170,1170,1200,1170,1200,1170,1200,1170,1200,510,6990;
20;2A;Debug;RTS P1;a21f0209359244;
20;2B;RTS;ID=359244;SWITCH=01;CMD=STOP;
