Help to build a python plugin
Posted: Sunday 24 September 2017 14:28
by TiXav
hello everybody,
I try to migrate a 2.7 python script to a 3.x python plugin
Today my script make a connection every X second to a dlink camera (2 dlink cams in fact DCS2210 & DCS2230) to retrieve the PIR state of each cam
My code is the following in the python script :
import urllib
	opener = urllib.FancyURLopener({})
	f = opener.open("http://user:pwd@ipaddress/config/io.cgi")
	aa=f.read()
I am looking for the same approach to do this in python 3.x. I found a lot of thing with google but it does not work
it would be great if someone coud give a boost
After testing, I will share it
thanks
TiXav
Re: Help to build a python plugin
Posted: Sunday 24 September 2017 15:09
by febalci
Will it be a plugin or script? Because you can use Domoticz Connection() method in Plugin.
If it's a script, use:
import urllib.request
response = urllib.request.urlopen("http://user:pwd@ipaddress/config/io.cgi")
and work on "response" variable.
Posted: Sunday 24 September 2017 15:41
by TiXav
It will be a plugin
thank you for the clue 'Domoticz Connection()', I am going to search in this direction
Posted: Thursday 28 September 2017 12:40
by zak45
or you can also
try:
        webURL=urllib.request.urlopen(Parameters["Mode4"], timeout=5)
        data=webURL.read()
        encoding = webURL.info().get_content_charset('utf-8')
        dataIP = json.loads(data.decode(encoding))
    except:
        Domoticz.Error ('Error to get public IP information')
Posted: Sunday 01 October 2017 21:21
by TiXav
All, thanks
I propose now the plugin. I tested it and I had no problem with
The plugin is usefull to retrieve data from url. depending of the result of the response (String to find for On update / String to find for Off update:), the plugin set a switch on or off in domoticz
I use it to retreive the state of the output of two cameras (DCS 2210 & DCS2230) :
I set up event in each cam to put the output to ON during 8 second when a movement is detected.
So the plugin is set up to retrieve the state of the cams each 4 seconds by retrieving the output state of cam with the following url http://IPADRESS/config/io.cgi
# PirCamChecker
# Author: TiXav, Sept 2017
# For My DLINK DCS2210 or DCS 2230
# I set the outpout of the camera On during 8 seconds when the cam detects someone
# So I set the Mode1 to 4 seconds to be sure the plugin catch all the detections
<plugin key="PirCamChecker" name="PirCamChecker" author="TiXav" version="1.0.0" externallink="">
    <params>
        <param field="Address" label="IP Address" width="200px" required="true" default=""/>
        <param field="Username" label="Username" width="200px" required="true" default=""/>
        <param field="Password" label="Password" width="200px" required="true" default=""/>
        <param field="Mode2" label="String to find for On update" width="200px" required="true" default=""/>
        <param field="Mode3" label="String to find for Off update" width="200px" required="true" default=""/>
        <param field="Mode1" label="Check Interval(seconds)" width="75px" required="true" default="4"/>
        <param field="Mode6" label="Debug" width="75px">
            <options>
                <option label="True" value="Debug"/>
                <option label="False" value="Normal"  default="true" />
            </options>
        </param>
    </params>
</plugin>
import Domoticz
import hmac
import hashlib
import time
import urllib
import urllib.error
#from urllib2 import urlopen
from datetime import datetime, timedelta
class BasePlugin:
    enabled = False
    pluginState = "Not Ready"
    sessionCookie = ""
    privateKey = b""
    socketOn = "FALSE"
    def __init__(self):
        self.debug = False
        self.error = False
        self.nextpoll = datetime.now()
        self.pollinterval = 60  #Time in seconds between two polls
        return
    def onStart(self):
        Domoticz.Debug("onStart called")
        self.pollinterval = int(Parameters["Mode1"])  #Time in seconds between two polls
        if Parameters["Mode6"] == 'Debug':
            self.debug = True
            Domoticz.Debugging(1)
            DumpConfigToLog()
        else:
            Domoticz.Debugging(0)
        # create the mandatory child device if it does not yet exist
        if 1 not in Devices:
            Domoticz.Device(Name="PIR_CAM", Unit=1, TypeName="Switch").Create()
            Domoticz.Log("Device created.")
        url = Parameters["Address"]
        ToFindOn=Parameters["Mode2"]
        ToFindOff=Parameters["Mode3"]
        #Create a password manager to connect to the camera
        password_mgr = urllib.request.HTTPPasswordMgrWithDefaultRealm()
        # Add the username and password.
        password_mgr.add_password(None, url, Parameters["Username"], Parameters["Password"])
        handler = urllib.request.HTTPBasicAuthHandler(password_mgr)
        # create "opener" (OpenerDirector instance)
        opener = urllib.request.build_opener(handler)
        # use the opener to fetch a URL
        f=opener.open(url)
        aa=f.read()
        VV = str(aa,'utf-8')
        VV.join(VV.splitlines())
        Domoticz.Debug(""+VV)
        PosOn=VV.find(ToFindOn)
        PosOff=VV.find(ToFindOn)
        Domoticz.Debug("PosOn="+str(PosOn)+"/PosOff="+str(PosOff))
        if PosOn>-1:
            UpdateDevice(1,1,"On")
        if PosOff>-1:
            UpdateDevice(1,0,"Off")
        # Install the opener. Now all calls to urllib.request.urlopen use our opener.
        urllib.request.install_opener(opener)
        aa = urllib.request.urlopen(url).read()
        Domoticz.Heartbeat(int(Parameters["Mode1"]))
    def onStop(self):
        Domoticz.Log("Plugin is stopping.")
    def onCommand(self, Unit, Command, Level, Hue):
        if Command=="On":
            Devices[1].Update(1, "1")
        if Command=="Off":
            Devices[1].Update(0,"0")
        Domoticz.Debug("onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
        for x in Devices:
                Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
        return
    def onHeartbeat(self):
        Domoticz.Debug("onHeartbeat called")
        now = datetime.now()
        if now >= self.nextpoll:
          self.nextpoll = now + timedelta(seconds=self.pollinterval)
          try:
            response = urllib.request.urlopen(url, timeout = 30).read()
          except urllib.error.HTTPError as err1:
            Domoticz.Error("HTTP Request error: " + str(err1) + " URL: " + url)
            return
          else:
            VV = str(response,'utf-8')
            PosOff=VV.find(ToFindOff)
            if PosOn>-1:
            if PosOff>-1:
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onCommand(Unit, Command, Level, Hue):
    global _plugin
    _plugin.onCommand(Unit, Command, Level, Hue)
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
# Generic helper functions
def DumpConfigToLog():
    for x in Parameters:
        if Parameters[x] != "":
            Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
    Domoticz.Debug("Device count: " + str(len(Devices)))
    for x in Devices:
        Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
        Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
        Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
        Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
    return
def UpdateDevice(Unit, nValue, sValue):
    # Make sure that the Domoticz device still exists (they can be deleted) before updating it
    if (Unit in Devices):
        if (Devices[Unit].nValue != nValue) or (Devices[Unit].sValue != sValue):
            Devices[Unit].Update(nValue, str(sValue))
            Domoticz.Log("Update "+"' ("+Devices[Unit].Name+") "+":'"+str(sValue))
    return
# Parse an int and return None if no int is given
def parseIntValue(s):
        try:
            return int(s)
        except:
            return None
