Page 1 of 7
Python Plugin: MeteoAlarmEU
Posted: Thursday 21 September 2017 12:15
by ycahome
Hi there.
I have managed to get data from MeteoAlarm RSS data from MeteoAlarm.eu site.
http://www.meteoalarm.eu/?lang=en_UK
Idea taken by korniza's post bellow:
korniza wrote: Monday 14 November 2016 16:19 ............. I found the following site that provides for EU weather warnings. The only problem is that I am not a coder.
SO if someone try to build it please take a look on http://www.meteoalarm.eu/ .
I suppose most people here are from EU countries...............
Plugin updates an "Alarm" Sensor with the warnings from this site. This value can be used later on in order to update any scripts or notify you upon difficult situations/do some protective actions on the house.
I hope you like it.
Find Version 1.0.2 bellow:
NOTE: This plugin requires feedparser to be installed with your python version
MeteoAlarmEU RSS Reader Plugin
Author: Ycahome, 2017
Version:    1.0.0: Initial Version
            1.0.1: Minor bug fixes
            1.0.2: Bug Correction
<plugin key="MeteoAlarmEU" name="Meteo Alarm EU RSS Reader" author="ycahome" version="1.0.2" wikilink="" externallink="http://www.domoticz.com/forum/viewtopic.php?f=65&t=19519">
    <params>
        <param field="Mode1" label="RSSFeed" width="400px" required="true" default="http://www.meteoalarm.eu/documents/rss/gr/GR011.rss"/>
        <param field="Mode3" label="Update every x minutes" width="200px" required="true" default="300"/>
        <param field="Mode4" label="Debug" width="75px">
            <options>
                <option label="True" value="Debug"/>
                <option label="False" value="Normal"  default="False" />
            </options>
        </param>
    </params>
</plugin>
import Domoticz
import json
import urllib.request
import urllib.error
from os import path
import sys
sys.path
sys.path.append('/usr/lib/python3/dist-packages')
import feedparser
from math import radians, cos, sin, asin, sqrt
from datetime import datetime, timedelta
class BasePlugin:
    def __init__(self):
        self.debug = False
        self.error = False
        self.nextpoll = datetime.now()
        return
    def onStart(self):
        if Parameters["Mode4"] == 'Debug':
            self.debug = True
            Domoticz.Debugging(1)
            DumpConfigToLog()
        else:
            Domoticz.Debugging(0)
        Domoticz.Debug("onStart called")
        # check polling interval parameter
        try:
            temp = int(Parameters["Mode3"])
        except:
            Domoticz.Error("Invalid polling interval parameter")
        else:
            if temp < 5:
                temp = 5  # minimum polling interval
                Domoticz.Error("Specified polling interval too short: changed to 5 minutes")
            elif temp > 1440:
                temp = 1440  # maximum polling interval is 1 day
                Domoticz.Error("Specified polling interval too long: changed to 1440 minutes (1 day)")
            self.pollinterval = temp * 60
        Domoticz.Log("Using polling interval of {} seconds".format(str(self.pollinterval)))
            self.debug = True
            DumpConfigToLog()
        else:
        # create the mandatory child devices if not yet exist
        if 1 not in Devices:
            Domoticz.Device(Name="Today", Unit=1, TypeName="Alert",Used=1).Create()
            Domoticz.Device(Name="Tomorrow", Unit=2, TypeName="Alert",Used=1).Create()
            Domoticz.Log("Devices created.")
        Devices[1].Update(0,"No Data")
        Devices[2].Update(0,"No Data")
    def onStop(self):
        Domoticz.Debug("onStop called")
    def onCommand(self, Unit, Command, Level, Hue):
        Domoticz.Debug(
            "onCommand called for Unit " + str(Unit) + ": Parameter '" + str(Command) + "', Level: " + str(Level))
    def onHeartbeat(self):
        now = datetime.now()
        rss=""
        feed=""
        FeedValueFTd=""
        FeedValueFTm=""
        if now >= self.nextpoll:
          self.nextpoll = now + timedelta(seconds=self.pollinterval)
          rss=Parameters["Mode1"]
          feed = feedparser.parse(rss)
          for key in feed["entries"]:
            FeedValue = str(key["description"])
            FeedValue = '<tr>TODAY ' + FeedValue.split('Today')[1]
            FeedValueFTd = FeedValue.split('Tomorrow')[0]
            FeedValueFTm = FeedValue.split('Tomorrow')[1]
            Domoticz.Log("Gathering Data for:"+str(key["title"]))
            if not (FeedValueFTd.strip().find('wflag-l1')==-1):
              Domoticz.Debug("Alarm(s) for Today: No special awareness required.")
              #Domoticz.Log("Data Of Warning:"+str(FeedValueFTd.strip()))
              Domoticz.Debug("Type Of Warning:"+str(FeedValueFTd.find('wflag-l1-t5.jpg')))
              Domoticz.Debug("Data:"+str(FeedValueFTd).replace('<','-'))
              ValueToUpdate="No special awareness required"
              #Devices[1].Update(1,ValueToUpdate, Image=Images[icon].ID)
              Domoticz.Debug("Current Awareness Status:" +  Devices[1].sValue + " with Level " + str(Devices[1].nValue))
              if (ValueToUpdate != Devices[1].sValue):
                Domoticz.Log("Awareness for Today Updated to:" + ValueToUpdate)
                Devices[1].Update(1,ValueToUpdate)
              else:
                Domoticz.Log("Awareness Remains Unchanged for Today.")
            else:
              Domoticz.Debug("------FEEDPARSER OUTPUT for TODAY:------------------")
              #Domoticz.Log("Type Of Warning:"+str(FeedValueFTd.find('wflag-l1-t5.jpg')))
              #Domoticz.Log("Data:"+str(FeedValueFTd).replace('<br>','').replace('</br>','').replace('<td>','').replace('</td>','').replace('<tr>','').replace('</tr>','').replace('<b>','').replace('</b>','').replace('<i>','').replace('</i>','').replace('<',''))
              FeedValueFTdPeriod = FeedValueFTd.split('<td>')[0]
              FeedValueFTdPeriod = FeedValueFTdPeriod.split('alt="')[1]
              FeedValueFTdPeriod = FeedValueFTdPeriod.split(':')
              Domoticz.Debug("Icon:"+FeedValueFTd.split('<td>')[0].replace('<','-'))
              AWTPossitions = FeedValueFTd.replace('<','-').split('awt:')
              #if AWTPossitions[2]: Domoticz.Log("AWT Possitions 2:"+AWTPossitions[2])
              WarningText = ""
              for AWTPos in range(1,len(AWTPossitions)):
                AWTvalue = ""
                LEVELvalue = ""
                AWTvalue = AWTPossitions[AWTPos].split('level')[0].strip()
                Domoticz.Debug("AWT Possitions Value "+str(AWTPos)+":"+AWTvalue)
                LEVELvalue = AWTPossitions[AWTPos].split('level:')[1].split('border')[0].replace('"','').strip()
                Domoticz.Debug("Level Possitions Value "+str(AWTPos)+":"+LEVELvalue)
                AWTtext =  AWTvalue
                if (AWTvalue == "1") : AWTtext = "Wind"
                if (AWTvalue == "2") : AWTtext = "Snow/Ice"
                if (AWTvalue == "3") : AWTtext = "ThunderStorm"
                if (AWTvalue == "4") : AWTtext = "Fog"
                if (AWTvalue == "5") : AWTtext = "High Temp"
                if (AWTvalue == "6") : AWTtext = "Low Temp"
                if (AWTvalue == "7") : AWTtext = "Coastal Event"
                if (AWTvalue == "8") : AWTtext = "Forestfire"
                if (AWTvalue == "9") : AWTtext = "Avalanches"
                if (AWTvalue == "10") : AWTtext = "Rain"
                if (AWTvalue == "11") : AWTtext = "Flood"
                if (AWTvalue == "12") : AWTtext = "Rain-Flood"
                if (AWTPos > 1): WarningText = WarningText + ", "
                WarningText = WarningText + AWTtext+"("+LEVELvalue+")"
                Domoticz.Debug("Alarm(s) for today:"+ str(WarningText))
              Domoticz.Debug("AWT:"+FeedValueFTdPeriod[1].split(' ')[0].replace('<','-').replace('>','-'))
              Domoticz.Debug("Level:"+FeedValueFTdPeriod[2].split('"')[0].strip().replace('<','-'))
              Domoticz.Debug("Period:"+FeedValueFTd.split('<td>')[1].strip().replace('<br>','').replace('</br>','').replace('<td>','').replace('</td>','').replace('<','-'))
              #Domoticz.Log("MessageLocal:"+FeedValueFTd.split('<td>')[2].split('.')[0].strip())
              #Domoticz.Log("MessageEn:"+FeedValueFTd.split('<td>')[2].split('.')[1].strip().replace('<','-'))
              #Domoticz.Log("MessageEn:"+FeedValueFTd.split('<td>')[2].split('.')[1].split('english:')[1].strip())
              #ValueToUpdate=FeedValueFTd.split('<td>')[2].split('.')[1].split('english:')[1].strip()
              if (LEVELvalue=="5"): LEVELvalue="1"
              if (WarningText != Devices[1].sValue) or (int(LEVELvalue) != Devices[1].nValue):
                Domoticz.Log("Awareness for Today Updated to:" + WarningText)
                Devices[1].Update(int(LEVELvalue),WarningText)
              else:
            if not (FeedValueFTm.strip().find('wflag-l1')==-1):
              Domoticz.Debug("Alarm(s) for Tomorrow: No special awareness required")
              #Domoticz.Log("Data Of Warning:"+str(FeedValueFTm.strip()))
              Domoticz.Debug("Type Of Warning:"+str(FeedValueFTm.find('wflag-l1-t5.jpg')))
              Domoticz.Debug("Current Awareness Status:" +  Devices[2].sValue + " with Level " + str(Devices[2].nValue))
              if (ValueToUpdate != Devices[2].sValue):
                Domoticz.Log("Awareness for Tomorrow Updated to:" + ValueToUpdate)
                Devices[2].Update(1,ValueToUpdate)
              else:
                Domoticz.Log("Awareness Remains Unchanged for Tomorrow.")
            else:
              #FeedValueFTm = FeedValueFTd.split('<tr>')
              Domoticz.Debug("------FEEDPARSER OUTPUT for TOMORROW:------------------")
              #Domoticz.Log("Type Of Warning:"+str(FeedValueFTm.find('awt:5')))
              FeedValueFTmPeriod = FeedValueFTm.split('<td>')[0]
              FeedValueFTmPeriod = FeedValueFTmPeriod.split('alt="')[1]
              FeedValueFTmPeriod = FeedValueFTmPeriod.split(':')
              Domoticz.Debug("Icon:"+FeedValueFTm.split('<td>')[0].replace('<','-'))
              AWTPossitions = FeedValueFTm.replace('<','-').split('awt:')
              WarningText = ""
              HLEVELvalue = 1
                AWTvalue = ""
                LEVELvalue = ""
                AWTtext =  AWTvalue
                Domoticz.Debug("Alarm(s) for Tomorrow:"+ str(WarningText))
                if (int(LEVELvalue) > HLEVELvalue): HLEVELvalue = int(LEVELvalue)
              Domoticz.Debug("AWT:"+FeedValueFTmPeriod[1].split(' ')[0].strip().replace('<','-'))
              Domoticz.Debug("Level:"+FeedValueFTmPeriod[2].split('"')[0].strip().replace('<','-'))
              #Domoticz.Log("Period:"+FeedValueFTm.split('<td>')[1].strip().replace('<','-'))
              #Domoticz.Log("MessageLocal:"+FeedValueFTm.split('<td>')[2].split('.')[0].strip().replace('<','-'))
              #Domoticz.Log("MessageEn:"+FeedValueFTm.split('<td>')[2].split('.')[1].split('english:')[1].strip().replace('<','-'))
              #Domoticz.Log(FeedValueFTm)
              #ValueToUpdate=FeedValueFTm.split('<td>')[2].split('.')[1].split('english:')[1].strip().replace('<','-')
              if (HLEVELvalue==5): HLEVELvalue=0
              if (WarningText != Devices[2].sValue) or (int(HLEVELvalue) != Devices[2].nValue):
                Domoticz.Log("Awareness for Tomorrow Updated to:" + WarningText)
                Devices[2].Update(HLEVELvalue,WarningText)
              else:
              Domoticz.Debug("----------------------------------------------------")
global _plugin
_plugin = BasePlugin()
def onStart():
    global _plugin
    _plugin.onStart()
def onStop():
    global _plugin
    _plugin.onStop()
def onCommand(Unit, Command, Level, Hue):
    global _plugin
    _plugin.onCommand(Unit, Command, Level, Hue)
def onHeartbeat():
    global _plugin
    _plugin.onHeartbeat()
#                   Device specific functions                     #
# Generic helper functions
def DumpConfigToLog():
    for x in Parameters:
      if Parameters[x] != "":
          Domoticz.Debug( "'" + x + "':'" + str(Parameters[x]) + "'")
    Domoticz.Debug("Device count: " + str(len(Devices)))
    for x in Devices:
      Domoticz.Debug("Device:           " + str(x) + " - " + str(Devices[x]))
      Domoticz.Debug("Device ID:       '" + str(Devices[x].ID) + "'")
      Domoticz.Debug("Device Name:     '" + Devices[x].Name + "'")
      Domoticz.Debug("Device nValue:    " + str(Devices[x].nValue))
      Domoticz.Debug("Device sValue:   '" + Devices[x].sValue + "'")
      Domoticz.Debug("Device LastLevel: " + str(Devices[x].LastLevel))
    return
# Parse an int and return None if no int is given
def parseIntValue(s):
        try:
            return int(s)
        except:
            return None
# Parse a float and return None if no float is given
def parseFloatValue(s):
        try:
            return float(s)
        except:
            return None
Installation instructions:
- Create Plugin Folder "MeteoAlarmEU" under "domoticz/plugins" folder
- Save this script as "plugin.py" on "MeteoAlarmEU" folder
- Restart domoticz service.
- Add a new entry of this Hardware on your domoticz installation (Setup/Hardware/select and add "Meteo Alarm EU RSS Reader")
What am going to see?:
- Plugin will auto-add two Alarm sensors on your "Utility" Section named "<Your Hardware Name>- Today" and "<Your Hardware Name>- Tomorrow".
Re: Python Plugin: MeteoAlarmEU
Posted: Thursday 21 September 2017 12:30
by kniazio
It does not work for me
Posted: Thursday 21 September 2017 12:39
by ycahome
please check depedencies (NOTE: This plugin requires feedparser to be installed with your python version)
and provide some logs
edited:to remove unidecode requirement
Posted: Thursday 28 September 2017 13:35
by ycahome
Updated to Version 1.0.1 with Minor bug fixes
Posted: Thursday 28 September 2017 15:23
by EdwinK
Now I need to figure out how to install those dependecies.
Requirement already satisfied: feedparser in /usr/local/lib/python2.7/site-packages
edit: Both installed. Keeping fingers crossed it works
Posted: Thursday 28 September 2017 15:34
by ycahome
i do have a synology DSM but never tested with domoticz and/or python.
You can try to install "pip" first and install packages through "pip" afterwards.
Check this article to get an idea.
https://primalcortex.wordpress.com/2016 ... installer/
Posted: Thursday 28 September 2017 15:43
by EdwinK
Yes, trying that out now. Now restarting Domoticz
by ycahome
Just realised that unidecode is not required (leftover from a test) so, you can mark as comment the following line
from unidecode import unidecode
to be :
#from unidecode import unidecode
No need to install unidecode anymore. (removed also from the initial post).
Posted: Thursday 28 September 2017 15:45
by EdwinK
Okay, going to change the line, although already installed the unidecode
Posted: Thursday 28 September 2017 15:56
by ycahome
OK, let me know if the plugin finally works for you!!
Posted: Thursday 28 September 2017 16:18
by EdwinK
not at the moment :(
017-09-28 16:13:20.914 (MeteoAlarm) Stopped.
2017-09-28 16:13:26.377 Error: (MeteoAlarmEU) failed to load 'plugin.py', Python Path used was '/usr/local/domoticz/var/plugins/MeteoAlarmEU/:/volume3/@appstore/py3k/usr/local/lib/python35.zip:/volume3/@appstore/py3k/usr/local/lib/python3.5/:/volume3/@appstore/py3k/usr/local/lib/python3.5/plat-linux:/volume3/@appstore/py3k/usr/local/lib/python3.5/lib-dynload'.
2017-09-28 16:13:26.377 Error: (MeteoAlarm) Module Import failed, exception: 'ImportError'
2017-09-28 16:13:26.377 Error: (MeteoAlarm) Module Import failed: ' Name: feedparser'
will try to investigate this after the weekend
Why do they have to make it so difficult with the various versions of python.
Well, after the weekend I've more time. I hope
Posted: Thursday 28 September 2017 16:47
by ycahome
seems that your "feedparser" is installed on python 2.7 while your path only contains python 3.5 locations.
So, i suggest either to install python3-feedparser or to include python 2.7 on your path settings.
sys.path.append('/usr/local/lib/python2.7/site-packages')
Posted: Thursday 28 September 2017 17:19
by EdwinK
Sounds Russian to me ;(
Posted: Thursday 28 September 2017 17:21
by zak45
EdwinK wrote: Thursday 28 September 2017 17:19 Sounds Russian to me ;(
:lol: :lol:
Posted: Wednesday 17 October 2018 21:37
by misko903
Looks useful, but hart to install for beginner.
Can you tell me, why I got these errors?
2018-10-17 21:45:18.134 Error: (MeteoAlarmEU) failed to load 'plugin.py', Python Path used was '/home/pi/domoticz/plugins/MeteoAlarmEU/:/usr/lib/python35.zip:/usr/lib/python3.5:/usr/lib/python3.5/plat-arm-linux-gnueabihf:/usr/lib/python3.5/lib-dynload'.
2018-10-17 21:45:18.134 Error: (MeteoAlarm) Module Import failed, exception: 'ImportError'
2018-10-17 21:45:18.134 Error: (MeteoAlarm) Module Import failed: ' Name: feedparser'
2018-10-17 21:45:18.134 Error: (MeteoAlarm) Error Line details not available.
I have tried the
pip3 install feedparser
but with the same result.
Maybe it can be added to Python Plugins Installer later?
Thx!
Posted: Tuesday 30 October 2018 13:31
by ycahome
misko903 wrote: Wednesday 17 October 2018 21:37 Looks useful, but hart to install for beginner.
I have tried the
Thx!
Hello misko903,
you are not the only one that have problems with python versions and plugins.
Read my conversation above with EdwinK to take an idea.
regards
Posted: Sunday 04 November 2018 20:03
by misko903
ycahome wrote: Tuesday 30 October 2018 13:31
I have tried the
Thx!
Hello misko903,
Hi Ycahome,
i came through all the posts before, tried several commands to install all the dependencies/libraries, switched default python parsers, trying to insert the path to the code, but without success... then I wrote this post.
Would it be hard to change the code to be usable for everyone? If yes, than let it be...
Thank you,
Michal, Slovakia
Posted: Thursday 08 November 2018 9:14
by ycahome
I have tried the
what was the output of "pip3 install feedparser"?
Installed correctly?
Posted: Thursday 08 November 2018 13:49
by misko903
ycahome wrote: Thursday 08 November 2018 9:14
I have tried the
like this:
pi@raspberrypi:~/domoticz/plugins/MeteoAlarmEU $ pip3 install feedparser
  File "/usr/bin/pip3", line 9, in <module>
    from pip import main
ImportError: cannot import name 'main'
Posted: Thursday 08 November 2018 14:08
by ycahome
Then your problem is still feedparser that was not on your system.
If you have python 3.x try :
sudo apt-get install python3-feedparser
