Notification for Garbage
mdo82
Post by mdo82 »
I have found a topic on this forum, which has made a LUA script through a waste collection website to see which container is to be put outside.
That is done in this topic (http://www.domoticz.com/forum/viewtopic ... 61&t=17963) Sharing : Afval kalendar in text sensor.
They have made a script that uses a website. However, in my homeplace, they do not use a website and want to try to get it together.
At this moment, I have a Dummy Switch in my domoticz that I wanted to use for this.
I have get the following code by reading several topic.
But how can i get it work so my switch is switching :D
week    = tonumber (os.date( "%V"))
dag      = tostring(os.date("%a"));
status   = tonumber(otherdevices_svalues['Afval'])
print('script bin_selector executed')
print ('Dag=  '..dag)
if (dag=='Sat' or dag=='Sun'  ) then
   weekend = true; weekdag = false
if (dag=='Mon' or dag=='Tue' or dag=='Wed' or dag=='Thu' or dag=='Fri') then
   weekend = false ; weekdag = true
--Bepalen morgen papier
if(week==2 and dag=='Wed' or week==4 and dag=='Wed' or week==6 and dag=='Wed' or week==8 and dag=='Wed' or week==10 and dag=='Wed' or week==12 and dag=='Wed' or week==14 and dag=='Wed' or week==16 and dag=='Wed' or week==18 and dag=='Wed' or week==20 and dag=='Wed' or week==22 and dag=='Wed' or week==24 and dag=='Wed' or week==26 and dag=='Wed' or week==28 and dag=='Wed'
	or week==30 and dag=='Wed' or week==32 and dag=='Wed' or week==34 and dag=='Wed' or week==36 and dag=='Wed' or week==38 and dag=='Wed' or week==40 and dag=='Wed' or week==42 and dag=='Wed' or week==44 and dag=='Wed' or week==46 and dag=='Wed' or week==48 and dag=='Wed' or week==50 and dag=='Wed' or week==52 and dag=='Wed') then
      morgenpapier = true; papier = false; plastic = false; niets = false
print ('morgen papier')
--Bepalen papier
if(week==2 and dag=='Thu' or week==4 and dag=='Thu' or week==6 and dag=='Thu' or week==8 and dag=='Thu' or week==10 and dag=='Thu' or week==12 and dag=='Thu' or week==14 and dag=='Thu' or week==16 and dag=='Thu' or week==18 and dag=='Thu' or week==20 and dag=='Thu' or week==22 and dag=='Thu' or week==24 and dag=='Thu' or week==26 and dag=='Thu' or week==28 and dag=='Thu'
	or week==30 and dag=='Thu' or week==32 and dag=='Thu' or week==34 and dag=='Thu' or week==36 and dag=='Thu' or week==38 and dag=='Thu' or week==40 and dag=='Thu' or week==42 and dag=='Thu' or week==44 and dag=='Thu' or week==46 and dag=='Thu' or week==48 and dag=='Thu' or week==50 and dag=='Thu' or week==52 and dag=='Thu') then
      morgenpapier = false; papier = true; plastic = false; niets = false
print ('vandaag papier morgen plastic')
--Bepalen plastic
if(week==2 and dag=='Fri' or week==4 and dag=='Fri' or week==6 and dag=='Fri' or week==8 and dag=='Fri' or week==10 and dag=='Fri' or week==12 and dag=='Fri' or week==14 and dag=='Fri' or week==16 and dag=='Fri' or week==18 and dag=='Fri' or week==20 and dag=='Fri' or week==22 and dag=='Fri' or week==24 and dag=='Fri' or week==26 and dag=='Fri' or week==28 and dag=='Fri'
	or week==30 and dag=='Fri' or week==32 and dag=='Fri' or week==34 and dag=='Fri' or week==36 and dag=='Fri' or week==38 and dag=='Fri' or week==40 and dag=='Fri' or week==42 and dag=='Fri' or week==44 and dag=='Fri' or week==46 and dag=='Fri' or week==48 and dag=='Fri' or week==50 and dag=='Fri' or week==52 and dag=='Fri') then
      morgenpapier = false; papier = false; plastic = true; niets = false
print ('vandaag plastic')
--Bepalen geen plastic en geen papier
if(dag=='Mon' or dag=='Tue' or dag=='Sat' or dag=='Sun') then
      morgenpapier = false; papier = false; plastic = false; niets = true
print ('vandaag geen afval buiten zetten')
if (niets and dag) then
      commandArray ['UpdateDevice']= '15|1|Geen ophaaldag'
if (morgenpapier and weekdag and dag) then
      commandArray ['UpdateDevice']= '15|1|Morgen papier'
if (papier and weekdag and dag) then
      commandArray ['UpdateDevice']= '15|1|Vandaag papier, morgen plastic'
if (plastic and weekdag and dag) then
      commandArray ['UpdateDevice']= '15|1|Vandaag plastic'
zicht
Domoticz version: 2023.1+
Re: Notification for Garbage
Post by zicht »
You are using the wrong format
commandArray['UpdateDevice'] = 'IDX'..'|0|'..whatever_your_variable_is
IDX needs to be replaced by the idx of you text device
you can find it in the sensor/devices (apparaten) table
Just lookup in that table you text sensor write down the idx number and construct the above using your values.
It should work that way !
Good luck :)
mdo82
Post by mdo82 »
Simply i had place the wrong hardware in my domoticz :roll:
He is working ;)
I still have a question about this.
I see my script running every 10 seconds, I had set the main device at 24 hours.
How it comes that the script still runs every 10 seconds?
Or is this a general setting within domoticz?
How can I get it that it's only once in 24 runs instead of every 10 seconds?
Is it also possible to change te image ?
zicht
Post by zicht »
Probably you have placed it in a device script.
You can place it in a time script to run once a minute but that's als not nice for the purpose.
time = os.date("*t")
if (time.hour==7 or time.hour==19) and time.min==0 then
the script
This would run the script twice a day in the moring and in the evening.
(i use this to send me a telegram reminder evening before and in the morning of the waiste day :D )
The image is (not yet) changeable for the text devices but you can include html with picture. In my experience that does not work nice, but has been some beta's agoo so maybe it works now in a better way.
note :
If you start experimenting and loose you text device due to this (had that before) just update it in a script with a one word text and it will reapear.
but maybe also that is improved in current versions.
