ENERWAVE DUAL RELAY SWITCH MODULE ZWN-RSM2
Posted: Monday 18 September 2017 21:42
by Xango
I want add to domotics three ENERWAVE DUAL RELAY SWITCH MODULE ZWN-RSM2, but is impossible with OenZwave Version: 1.4-2501-g5af6780-dirty that not include this device. I have try to add xml in Config/enerwave :
<?xml version="1.0" encoding="utf-8"?>
<Product>
<Model>ZWN-RSM2</Model>
<Label lang="en">Smart Dual Relay Switch Module</Label>
<CommandClasses>
<Class><id>0x20</id></Class>
<Class><id>0x30</id></Class>
<Class><id>0x70</id></Class>
<Class><id>0x71</id></Class>
<Class><id>0x72</id></Class>
<Class><id>0x80</id></Class>
<Class><id>0x84</id></Class>
<Class><id>0x85</id></Class>
<Class><id>0x86</id></Class>
</CommandClasses>
<Configuration>
<Parameter>
<Index>3</Index>
<Type>byte</Type>
<Default>0</Default>
<Minimum>0</Minimum>
<Maximum>255</Maximum>
<Size>1</Size>
<Label lang="en">Unsolicited Report Configuration</Label>
<Help lang="en"><![CDATA[ZWN-RSM2 can send unsolicited status report to primary controller (Node ID 0X01) when switch toggled due to some controllers designed as gateway. If your controller is not a gateway or does not need the status or you think it could confuse your Z-Wave network, you can use Command_Class_Configuration to disable this function. By default setting, this function is disabled.<br/><ul><li>0 = Disabled (Default)</li><li>1-254 = Other controller ID</li><li>255 = Send broadcast.</li></ul>]]></Help>
</Parameter>
</Configuration>
</Product>
but when restart the file is empty. What is the procedure to add a unknown device ?
