Notification if power consumption is too high
Posted: Sunday 17 September 2017 22:14
Hi all, I am tryting to find a solution for the following:
If the amound of electricity I'm using is above a certain kWh , for more than 10 minutes, I want to be notificated.
How can I do that? I tought to make a dummy switch with a delay. But when the power is above the amound of kwh, the delayed switch will go on, even if after the 10 minutes the kwh is at a normal point again.
I would also like to do a similair thing with my door sensor. If the door is open for more than 5 minutes or so, I want to be notificated.
