Mysensor gateway node is not connecting
Posted: Friday 15 September 2017 23:45
by Misterik
I changed to new router. After this i only have problems with mySensors gateway. It will not connect. I am now lost i tried a lot of things...but i don't understand why it is not connecting.
My setup is:
- Domoticz v3.8394 on RPI
- Mysensor node : ESP Easy NodeMCU
My log is saying:
2017-09-15 23:21:27.287 New sensors allowed for 5 minutes...
2017-09-15 23:21:28.954 TCP: Reconnecting...
2017-09-15 23:21:29.955 Error: MySensors: Can not connect to: 192.168.1.113:5003
2017-09-15 23:21:29.955 TCP: Connection problem (Unable to connect to specified IP/Port)
2017-09-15 23:21:29.955 TCP: Reconnecting in 30 seconds...
From pi RPI i can ping the mysensor IP
pi@raspberrypi:~$ ping 192.168.1.113
PING 192.168.1.113 (192.168.1.113) 56(84) bytes of data.
64 bytes from 192.168.1.113: icmp_seq=1 ttl=128 time=9.43 ms
64 bytes from 192.168.1.113: icmp_seq=2 ttl=128 time=9.56 ms
64 bytes from 192.168.1.113: icmp_seq=3 ttl=128 time=10.0 ms
64 bytes from 192.168.1.113: icmp_seq=4 ttl=128 time=10.6 ms
I can connect with browser to mysensor node:
The following things i checked:
  • all components are on the same IP-range
  • in the settings page i set the 'local notwork'
  • I built a new node but this new node gives the same problem.
  • ect.
Anyone have a clue? Thanks in advance.
Re: Mysensor gateway node is not connecting
Posted: Sunday 17 September 2017 17:23
by Misterik
Topic can be closed...i forgot to update the gatewayESP8266 sketch with the router information. I totally forgot this sketch, i though flashing the nodeMCU was enough
