.filter pattern and functions
Posted: Thursday 14 September 2017 14:04
by emme
Ciao,
I'm approaching dzVents and it's simply fantastic...
I have a doubt about the .forEach function and the search pattern in case of browsing common devices...
example...
I have my BLE devices that have the profix NUT_ so, at the moment I found them with
domoticz.devices().forEach(function(device)
            if (device.name:sub(1,4) == 'NUT_') then
but I'm wondering there is the possibility to use or create a different way like
domoticz.devices().forEach(device).filter(.name:sub(1,4) == "NUT_')
is it possible... and if so how, to create function within the Execute section?
like
function retTrue():
   return true
print(tostring(retTrue))
thanks
ciao
M
Re: .filter pattern and functions
Posted: Thursday 14 September 2017 14:55
by dannybloe
You have to turn it around. First you do the filter and with the filtered results you do the forEach:
domoticz.devices()
	.filter(function(device)
		return (device.name:sub(1,4) == 'NUT_')
		-- do something with device
The filter function returns list that you can use in combination with .reduce or .forEach. forEach doesn't return anything so there the 'chain' ends.
And your other question:
You can create functions anywhere in the module:
local myFuncA = function()
	-- do something
		local myFuncB = function()
			-- do something else
		-- call the functions
		myFuncA()
		myFuncB()
Just don't forget to declare all your functions and variables as locals so they don't interfere with other modules.
